elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Thu Nov 06, 2003 5:00 pm
Ill try and go in order, and BTW welcome to NICO......
Im not sure where the best place to go is, but Id talk with Q45tech to see where T-3 in atlanta gets their engines.......
It is true that the Japanease take out engines DO only have 40-60k..... To make a long story short, they only drive really small distances, and they have a very hard inspection program, and after 60k it becomes financially stupid to keep the car, so they sell it and it eventually gets parted out......
The easiest way to tell if the engine was truely JDM is if there are no precats on the exhaust manifold..... Some have hte JDM plenum, but others that are known to be from Japan dont (IE have the USDM plenum)....
I would assume youd want compression to be in spec (185PSI, with no more than 14 PS difference between cylindersI, minimum is 142)
The engine WILL NOT have the proper chain guides, and those will need to be fixed prior to installation in the car.......
