VGDime wrote:i have an autometer gauge and i have the 1/4 square drive cable already. It threads on to the transmission but i think there is plate of some time that screws around the threads and locks that part down. also it should have the "adapter" that allows the cable to spin. Right now the cable just goes into a spring looking thing that is bigger then the cable and i was told that the stock part that is missing brings that down to the 1/4 square drive
thanks for all the help
Okay. Now you're confusing me. Are you saying you already have the appropriate cable? Where did you get it from? Autometer?
And you have a pinion gear. Do you mean the whole assembly or just the gear?
The pinion gear assembly just presses into the transmission. There is a small metal tab that slips into that small notch and holds it in place. If you do have the whole assembly, the cable should just screw onto the assembly. If not, you'll need to contact Autometer about an adapter.
If this doesn't answer the question, then pictures would help.
