NC SC CHAT
Including AR, LA, MS, AL, FL, GA, SC, and NC
Zee
Car: 99 Chevy Cavalier
Welcome and nothing is off topic in this thread.
S13NismoStyle
Car: 1993 Nissan 240sx Fb
To E7-S14 yeah thats fine, the motor isnt going anywhere. And if you have 250whp in a ka your prolly making atleast that much torque. So yeah, you will be able to destroy tires pretty easily.
Ive managed to eat through a set of g-force sports in about 6 weeks with my sr. and thats just beating on it.
Ok, now this gets long. So dont worry about reading it if you dont want to.
But in all honesty. I would get new pistons, JE pistons will be fine. New timing set and oil pump. Go with OEM for these, DO NOT SKIMP. You will need to have a machine shop check your crankshaft to make sure everything is all good. If it isnt, you can either have your crank polished or turned. If it gets turned you would have to purchase over sized bearings.
But have your cylinders bored. (You need the pistons first before this gets done, becuase they will hone each cylinder per piston. the pistons will be numbered when you get them back.) If you are reusing the rods, you can have the ends checked to make sure everything is to Spec or True. Then assemble the bottom end following the fsm. Make sure you have a good torque wrench. Also, be sure you put engine oil on every bolt before you put them in.
As for the head, i would get a valve job, valve stem seals and just have the machine shop make sure everything is in spec. That is probably the most important part. The machine shop should be able to assemble your head for you. be sure to use all new gaskets and what not.
Or you could just do it like jordan and devon. You might get lucky
triple240
Car: 89 coupe
you guys damn right im the motor killing king and i didnt mic the crank because somebody (chris) told me the crank was fine and not shaved or anything.
triple240
Car: 89 coupe
but as jordan and chris are saying i would learn from me jordan and brandons mistakes. just make sure you have a machine
scs13
Car: 93 s13 coupe
hey now, my motor runs like a champ, and so will the one for the fastback. devon just kills motors so hard it doesnt even make sense.
jaxiss
Car: 92 240sx coupe{sold)/ 05 altima(gone with the x) / 91 sonoma(sold)/93 s13 vert(for sale)/ 98 z34 monte
lol. yeah i would deffinitly go the machine shop route. spending all the money on parts and time putting together makes it a real b;+ch when it blows up because of something that could have been simpley prevented. also (im sure you've heard this before) but be extremely carefull on assembly not to get any trash in the bearings, they are easy to kill that way. of course i really can't talk since i bought my 240 with spun rod bearings and just emory clothed the journals and put in bearings and drove.
S13NismoStyle
yeah the crank was fine. But you should ALWAYS atleast plastigauge the crank, both main bearings and rod bearings. We plastigauged my friends crank and it was brand new. I dont know about you, but i cant see down to the 1/100th of an inch . But anyways, i thought that you said that your ebay oil pump fubar'd on ya devon?
And sorry to hear about your motor jordan.
scs13
Car: 93 s13 coupe
yeah, idk whats up with devon and killing oil pumps. thats the second one that just straight crapped out.
but yeah dude, that ****s riddiculous. i have no idea wtf happened, it was the weirdest **** ever. pretty much the worst day ever. guess im gonna work on it today and see if i can figure out what the problem is. gonna be hard to test compression on cyl 2
S13NismoStyle
Man that does suck. I dont know what to tell ya. Just get the hb running and sell that *****
Well, i got some thing kinda cool to tell ya. I did a random search on google images for an s13 and your sig pic was one of the first pictures that came up.
triple240
Car: 89 coupe
brandon your a *** and atleast i drive my 240 yours just collects dust and you still cant even get it running. and when im done my car it will look a hundred times better than yours and it will be faster vroooompshhh. and jordan your a *** tooo and today i blew out a brand new tire
scs13
Car: 93 s13 coupe
LOL
thats awesome, i am 73|-| |\/|4$73|2 0F 73|-| 1|\|7|24\/\/3|3!!!11!!11!!!!eleven!!!one1
newbs - the master of the interweb
dalzell240
Car: '95 Nissan 240SX Red
thats for talkin all that s**t
triple240 wrote: and today i blew out a brand new tire
scs13
Car: 93 s13 coupe
dude shut the hell up, why are you even on here.
The Duke
Car: 1989 nissan 240sx fastback
Yeah, I'm with Devon here. It's disgusting to me how much Brandon's car just sits around. I've seen it on the road once since it was turbo. Get it straight man. Start driving it.
E7-S14
Car: ess 14 foo!
Thanks for the Advice S13NismoStyleit will def. come in handy..
but Ive slightly changed my plans..as of now. I'm looking for a Running Good shape 95+ KA w/ 5speed trannylooking to spend >500...
I want to swap in the new KA and do 5speed swap on the car so I could have something to enter events with.my transmission is really holding me back as of now.
I plan to pull my current motor and start the rebuild on that..but I honestly need to start entering events
triple240
Car: 89 coupe
hey guys
triple240
Car: 89 coupe
man i found an emanage ultimate with harness and boost press sensor for four hundred
triple240
Car: 89 coupe
but i dont have ten post on my new account so i cant post in classifieds
triple240
Car: 89 coupe
but now i do!!!!!!!!!yaaaaaa
Zee
Wow you are an idiot and I am going to get your post count deleted. You damn retard.
scs13
Car: 93 s13 coupe
hahaha what the hell is wrong with you kids. its a new account and he needs to sell some ****, shut the **** up. he could have just posted on my name anyways.
Knotmaster
Car: 89 240sx
Give me some money luck and I will drive it My car never gets driven cus it blew the **** up 2 times now and now and im out of money to fix it . Till I get a job **** messing with that car.
smurf13
Car: 1992 Nissan 240SX fatback
wow...it got pretty intense up in this thread
Modified by smurf13 at 11:17 PM 12/23/2007
triple240
Car: 89 coupe
Zee wrote:Wow you are an idiot and I am going to get your post count deleted. You damn retard.
what the hell is wrong with you i specifically stated that it is my second account and i couldnt post in the classifieds so chill out ok wo wo wo wo wo
triple240
Car: 89 coupe
thanks Jordy matt hahahahahahah
Zee
It is simple people don't get away with post whoring in order to post in classifieds. Why should you be any different? You should be a productive member of the forum, not some little ****er that thinks because he has a friend on the forum his is better than someone else. Stop thinking that you are better than the rest and actually post something worthwhile.
Also, learn how to use punctuation because it is really hard to read a run-on sentence.
Anyway that is what I am saying try to think about it before you think for some reason that because you have a "friend" on the forum that for some reason you are above the rules.
triple240
Car: 89 coupe
i already had an account on nico for about three years but i got a new email adress and couldnt remember my password. so chill the **** out damn. i am a productive member of the forum ive probly been on here longer than you have so chill out and stop crying.
The Duke
Zee, I don't know if you've noticed, but most of us are friends here. You're the odd man out. Quit trying to police these forums.
The Duke
Knotmaster wrote:Why so he can **** all of them up too
Knotmaster wrote:My car never gets driven cus it blew the **** up 2 times now
Right right.
The Duke
Zee wrote:Also, learn how to use punctuation because it is really hard to read a run-on sentence.
You are a model of good grammar and easy to read sentences...
Return to “Southeast Region”
