I'm assuming you're talking to me here?Td5turbo wrote:Those sizes are pretty weak for a S14. I dont know if ubber flush is your thing, but I would go with some 20mm-25mm spacers to bring the offset to around +15/+10. You will probably need some camber and a slight fender roll (but no pull). And also flushness depends on tire choice.
Ultimatly it comes down to a few factors:What carHow you plan to use the car (drift, road race, drag, daily, etc)How much hp you havehow much your willing to spend
If you give answers to those questions, it will be way easier to pick out tires.
hook me up man! oh yeah, btw, in case it matters, my car is sitting on Eibach sportline springs and kyb GR2 struts in the rear, front struts are still stock, and I've done nothing to the camber or anything else. I'm open to suggestions on suspension upgrades considering what I told you guys in my previous post. I have not bought front struts, and would not be opposed to suggestions about changing the rears. Do you guys think if I went a little more extreme up front that I would be in need of matching up the rear immediately?kaChris803 wrote:well, just like austin said, it all depends on your driving style (good post austin!!! you should be a lawyer or something!!!), but i can get you a hell of a deal on tires when you decide which one's your going to go with.
this is why i agrue my point, for ride quality and handling you would want a larger sidewall and a "wider footprint"maxima278 wrote:
What I want to use the car for?ok, mainly I want this car to be set up for mountain driving, I do not want to lose grip in the corners. I'll probably experiment with drifting a little, but ultimately I'm planning to build an S13 for that sole purpose, plus I'll have plenty of extra wheels and tires around to waste (I have 2 sets of s14 se's, and some 15 inch maxima wheels). I'd like to keep the ride as smooth as possible, but I'm looking for handling.
I believe that you definitely need to upgrade your front setup. IMO you should just duplicate your rear setup for now until you decide on something else.maxima278 wrote:
yeah that was always the plan, I just did the rears because they blew immediately and the front did not seem to do so bad. I didn't have a lot of money at the time so I put the fronts on the backburner. I don't know if the KYB's are really an upgrade over stock, at least they don't really feel like it, that's why I said I was open to other options. What if I went with something adjustable, or at least a different brand up front? Would that adversely affect the rears w/ the kybs?gr8bryt wrote:I believe that you definitely need to upgrade your front setup. IMO you should just duplicate your rear setup for now until you decide on something else.
Ok, what if I keep the staggered wheels (which are only an inch different in width), but get the same size tires all around, will that still give me significant understeer? I'm getting a killer deal on these wheels but I don't want to crash and die. That would suck, for me and my car. So, I'm gonna play devils advocate a little bit here and act stubborn so that I can find out if these wheels are going to be ok or not. I wish I could post a pic but the picture posting gallery is down.... I tried just the 18x8.5s on one side of the car just to look at it once when I was up at Brandon's. It looked beautiful with the 245's on it.Td5turbo wrote:Well in your case, I would sell the staggered setup. The S14 can tuck huge wheels with awesome offsets. The reason I say that is your looking at just over 210whp with a SR with bolt ons and no tune. If you put a staggered setup on that and run 245-255 on the rear and 225-235 on the front, your car is going to push like hell through corners especially with stock struts up front. You could upgrade the rear sway bar to try and solve the problem but your still going to get understeer like crazy (which is not good in the mountains). My suggestion is to go with a different wheel.
ok, first take the thermostat out, and throw it away, I did without one on my KA all winter and was fine. The exhaust leak can probably be fixed easily by tightening some bolts or replacing with components from your other car. Low idle... not sure. try swapping the maf sensor over from the other car. Burns oil? Just keep adding oil when it gets low. Speedo, perhaps swap gauge cluster from other car? Hatch is rusty, get it off the other car. Frame still bent? Maybe you should be working with the red car to begin with. just because the black one runs doesn't mean it's the best one to fix up. Don't know what to tell you about the valves.Black on Gold wrote:Lets see, my car idles low, burns oil, has an exhaust leak, thermostat doesnt work, speedo doesnt work, frame is still not straight, Mass amounts of rust on the hatch, problems with the valves, auto, body is in terrible terrible condition. SO that pretty much sums it up guys.
