lexcrob wrote:I read a few times over.
Im assuming maybe you put in new spark plugs and after 10 min of running ok it then runs bad.
You then pull out the plugs and they are covered in carbon.
Id maybe suspect bad gas. Fault codes set? Large vacuum leaks?
How long has it been sitting or did the problem just begin out of nowhere?
Really need more information to give better feedback.
We bought the car off some other guy so its definitly been sitting awhile. And yea after putting new plugs in and run it, it runs perfectly fine until you shut it iff then goto start it again. We ran it almost out of gas so i dont think theres any old gas left in it. We did the timing after the problem already was there assuming maybe the timing was causing the issue and the issue was still there.
