NISMOZ04 »
https://forums.nicoclub.com/nismoz04-u102966.html
Tue Aug 05, 2008 7:22 am
My 2004 Z has NISMO cold air intake, cams, headers, cat back exhaust, motordyne plenum spacer and a reflasfh from Technosquare. My motor was 287 bhp stock and 222 actual rwhp before I started in 2004.
At Technosquare recently it put down 269 rwhp, but we weren't seeing the expected gains from the cams from 6600 to 7100 rpm The reflash raised the rpm red line). This is likely about 330 bhp at the crank.
Tadashi suggested a colder plug might help. My car had 70,000 miles on it when we did the dyno, so this engine is a little tired.
Different dynos produce different results, but my mods appear to have added 47 rwhp and a lot of torque.
Newer Z's come with a higher stock output and should see the same performance numbers with a smaller investment.
Th best performance bang for the buck from my mods was the 5/8" Motordyne plenum spacer.
My advice is to buy a newer Base Z (very light, no electronics) and spend the money on tires, wheels, brakes, sway bars and suspension......
