It has been awhile...
Anyway - so, tonight did compression test. 1-2-3-4, got 150-135-135-150. with harbor freight compression tester tool.
FSM says that normal compression would be 200 and minimal 175, with deviance no more than 14 between cylinders.
I think I saw pretty much the same values like ~4yrs ago. Except now I have P0303 (misfire in 3rd cylinder). and vibrations up to, approx, 1700rpm.
put it new spark plugs(4yrs ago installed denso 3490, they did ~80kmiles, now 2 and 4 had gaps 0.055 instead of 0.044). swapped coils 3-1. still the same.
Right now I think it might be injector... probably time for aceton coctail
But what are your typical values? And what do you think about valve adjustment? I think I saw it somewhere in FSM about checking those ~60kmiles, but now can't find it... may be I was just dreaming
