My truck wont start
1972-1979 Datsun 620 forums. All 620-specific topics and discussion can be found here.
dfresh777
Car: Datsun 620 Pickup
Hi My Name is Daniel,
i have a Little Hustler datsun 620 series. we have rebuilt the Carberator, put on a new fuel pump, new distributor and cap, drained fuel tank, blew out fuel lines. if you put gas in to the Carberator it will fire over till that is gone, but its not sucking fuel into the carb. need help to get this truck back on the road.
PEZi
electric or manual fuel pump?
dfresh777
Its a Manual Fuel pump, we tested it before we put it in
PEZi
well it sounds for sure as if its not getting fuel... the question is why
have you tried pulling the fuel lines at various places to see where the fuel stops flowing?
dfresh777
I will look in to the fuel lines and see where i get, thank you i will update after my search
dfresh777
Do you Happen to know where i can find a Fuel Line Diagram?
PEZi
i'll see if i can find a 620 specific one... we're working on getting more of that here for our forums but as of now we don't have anything on hand
dfresh777
I got it started today, it ran on its own till everything warmed up then it started to die on me, so i gave it a little gas and it back fired on me twice. it kind of chokes when you slowly rev it up and let off. i did turn it off and back on then it ran again on its own for 15 minutes. what should the Idl be, any suggestion so it runs smooth and starts when you turn the key done not have to crank a few times?
PEZi
well... first things first... check all you vac lines and such. your timing might also be off by the sounds of it. the idle on a manual should be around 800 when warm and 900 for an auto
dfresh777
Thank you, it is a 4 speed. i have checked all vacume lines yesterday. its been 4 years since it was on the road so im sure its got a little build up. i will ook more in to is saturday when i am messingin with it again.
Return to “Datsun 620”
