my swap.
ILoveMyRHS13
Car: 1990 Nissan 240sx (Hatch)
Yeah, 5 speed swaps aren't fun to find the parts. I got lucky and found a trans with 88k on it but I over-payed for it but I needed it, so it's all good. Just don't give up.
rsagen
Car: 1989 240SX Coupe 5sp SOLD
1989 240SX Hatch auto SOLD
1990 240SX Coupe auto WRECKED
1990 240SX Hatch auto
1990 Jetta Turbodiesel 5sp FEILD BAGGED
1997 Jimmy 4WD
1985 Chev Wrangler
1994 F150 4X4
Tomorrow instead of going out drinking I think I'm going to start creating a shifter. Maybe cut out the shifter hole bigger. I'll post photos of my progress, maybe someone else will use this as info if they decide to get the same transmission. The drive shaft is going to be tooken to a shop to be extended. Also ill post up my todo list I made up.
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
6 posts in a row fail.
So you decided to keep this transmission and just make it work? I may be able to find you a bell housing if you'd rather.
rsagen
1997 Jimmy 4WD
1985 Chev Wrangler
1994 F150 4X4
i didnt no it posted that many times
Razi
Car: Moo
Click "Edit"Then "Delete"
krash
dang dude, if you were closer by I'd give you my extra 5spd trans for like 60 bucks, since you're having so much trouble Kudos for truckin through though man! (get it? "Truckin" )
rsagen
1997 Jimmy 4WD
1985 Chev Wrangler
1994 F150 4X4
Razi wrote:Click "Edit"Then "Delete"
I actually didnt no that button was there, well its fixed now. thanks for letting me know about that.
Anyways I decided to slow down on my build, moneys not free right? and i got pretty used to no wheels for about 3 months now.
well Im getting the driveshaft extended and balanced at a place that i no the owners for 50 to 75 bucks, going to keep it a two piece tho.
buddies comin sometime this week with oxy setaline (spelling wtf) and with that and my welder we are going to create a shifter that will work. Im cutting 2 inches more forward in the shifter hole in the car as well. Im still going have it come up where it should, cuz i wanna keep the stock look and feel for resale value down the road.
thanks for everyones support!
motoman399
Car: 98' wrecked (RHD coming soon) 240
rsagen wrote:buddies comin sometime this week with oxy setaline (spelling wtf) and with that and my welder we are going to create a shifter that will work. Im cutting 2 inches more forward in the shifter hole in the car as well. Im still going have it come up where it should, cuz i wanna keep the stock look and feel for resale value down the road.
you could always make a shifter extension with a plate that bolts onto the trans
i drew this up in paint real quick. i think you would need to use heim joints to make it work. and it would probably be backwards shifting (but no one would be ably to steel your car haha)
plate
heim jointhttps://catalog.foothilloffroa...m.gif
rsagen
1997 Jimmy 4WD
1985 Chev Wrangler
1994 F150 4X4
plate
I was thinking about doing that too but I wasnt sure how a guy would go about doing it. Just not sure if it was possible to shift to like the side. I figured it would go into 3rd and 4th easily but without some second pivit point i dont no about any other gears.
thanks
motoman399
i think you would need a heim joint on the red line and a solid mount on the shifter. i think it would work. but i dont know for sure. it would be pretty crazy to have to shift in reverse order though. be kinda fun lol
rsagen
1997 Jimmy 4WD
1985 Chev Wrangler
1994 F150 4X4
I am going to talk to a few local mechanics about this....
Before i do any more cutting and welding and swearing I am going to think this through and plan it 100%.
Let my mistakes be everyone elses knowledge! lol
motoman399
figured it out, with adjustments
this will shift in the normal shift pattern. it will work if you can fabricate. good luck
rsagen
1997 Jimmy 4WD
1985 Chev Wrangler
1994 F150 4X4
I found a 240sx 5 sp transmission for 100 bucks on kijiji
so this is the way i see it....
100 bucks for the transmission OR 100 bucks for a driveshaft frabcation plus create a shifter.
so as long as the new clutch will work im going to get a car transmission...
any ideas now lol.
motoman399 wrote:figured it out, with adjustments
thank you for the info. just have to see how it goes.
motoman399
you can always look up part numbers on the clutch. feel free to send me parts from the trans. lol good luck
rsagen
1997 Jimmy 4WD
1985 Chev Wrangler
1994 F150 4X4
Already did. Diff part numbers. Car trans has inch less on the diameter. Thinking is should work .
rsagen
1997 Jimmy 4WD
1985 Chev Wrangler
1994 F150 4X4
I can see the light at the end of the tunnel..
So tonight I just picked up a transmission for 100 bucks. The guy didn't want the motor so a ka24de came with. He was swapping in an Sr . Has 130,000 on it and runs strong. He is also selling me the newer style front bumper. Still the pop up headlights but not the pignose if that makes sense.
rsagen
1997 Jimmy 4WD
1985 Chev Wrangler
1994 F150 4X4
I got the car running and drivin tonight! Once I got the correct transmission it was a piece of cake. And I have nico and of course all my buddies who turned a wrench to thank!! Next step is the cruise and backup lights.
