SteveTheTech »
https://forums.nicoclub.com/stevethetech-u103802.html
Sat Jan 03, 2009 12:33 pm
A/T SHIFT LOCK SYSTEM
Diagnostic Procedure SYMPTOM 1:Selector lever cannot be moved from “P” position with key in ON position and brake pedal applied.Selector lever can be moved from “P” position with key in ON position and brake pedal released.Selector lever can be moved from “P” position when key is removed from key cylinder.
SYMPTOM 2:Ignition key cannot be removed when selector lever is set to “P” position.Ignition key can be removed when selector lever is set to any position except “P”.
1.CHECK KEY INTERLOCK CABLE
Check key interlock cable for damage.OK or NG
OK >> GO TO 2.
NG >> Repair key interlock cable. Refer to AT-296, "KEY INTERLOCK CABLE" .
2. CHECK SELECTOR LEVER POSITION
Check selector lever position for damage.OK or NGOK >> GO TO 3.NG >> Check selector lever. Refer to AT-289, "Adjustment of A/T Position" .
3. CHECK POWER SOURCE1. Turn ignition switch ON. (Do not start engine.)2. Check voltage between A/T device harness connector M47 terminal2 (Y/G) and ground.OK or NGOK >> GO TO 5.NG >> GO TO 4.
4. DETECT MALFUNCTIONING ITEM
Check the following items:1. Harness for short or open between ignition switch and A/T device harness terminal 2
2. 10A fuse [No.12, located in the fuse block (J/B)]
3. Ignition switch (Refer to PG-3, "POWER SUPPLY ROUTING CIRCUIT" .)OK or NGOK >> GO TO 5.NG >> Repair or replace damaged parts.Voltage: Battery voltage
A/T SHIFT LOCK SYSTEM5. CHECK INPUT SIGNAL A/T DEVICE-Turn ignition switch OFF. -Check voltage between A/T device harness connector M47 terminal 4 (OR) and ground.OK or NGOK >> GO TO 7.NG >> GO TO 6.
6. DETECT MALFUNCTIONING ITEMCheck the following items:1. Harness for short or open between battery and stop lamp switch harness connector 1
2. Harness for short or open between stop lamp switch harness connector 2 and A/T device harness connector 4
3. 10A fuse [No.20, located in the fuse block (J/B)]
4. Stop lamp switch– Check continuity between stop lamp switch harness connector terminals 1 (R/Y) and 2 (P/[/color=blue]L(yes blue)[/color]).
-Check stop lamp switch after adjusting brake pedal — refer to BR-6, "BRAKE PEDAL" .OK or NGOK >> GO TO 7.NG >> Repair or replace damaged parts.
7. CHECK GROUND CIRCUIT
1. Turn ignition switch OFF.
2. Disconnect A/T device harness connector.
3. Check continuity between A/T device harness connector terminal 1 (B) and ground.If OK, check harness for short to ground and short to power.OK or NGOK >> GO TO 8.NG >> Repair open circuit or short to ground or short to powerin harness or connectors.Voltage:Battery voltageBrake pedal depressed:0VBrake pedal released: Continuity should not exist.Brake pedal depressed: Continuity should exist.
8. CHECK PARK POSITION SWITCH AND RELAY CIRCUIT (COIL SIDE)
Check continuity between A/T device harness connector terminals 1 (B) and 4 (OR).OK or NGOK >> GO TO 9.NG >>Replace park position switch or relay.Repair open circuit or short to ground or short to power in harness or connectors.
9. CHECK SHIFT LOCK SOLENOID AND RELAY CIRCUIT (POINT SIDE)1. Connect A/T device harness connector.
2. Turn ignition switch ON. (Do not start engine.)
3. Check shift lock solenoid and relay operation.OK or NGOK >> GO TO 10.NG >>Replace shift lock solenoid or relay.
10. CHECK SHIFT LOCK OPERATION1. Connect A/T device harness connector.
2. Turn ignition switch from OFF to ON. (Do not start engine.)
3. Recheck shift lock operation.OK or NGOK >> INSPECTION ENDNG >> GO TO 11.
11. CHECK A/T DEVICE INSPECTION
1. Perform A/T device input/output signal inspection test.2. If NG, recheck harness connector connection.OK or NGOK >> INSPECTION ENDNG >> Repair or replace damaged parts.
I don't know if this helps much but this will show you what needs to be looked into to diagnose this. I have a sneeking suspicion you may have done something when replacing the battery. The easiest thing to look into would be the brake position switch. There should be about ~0.0080" clearance between the brake pedal switch and the pedal itself. Good Luck.
