No, no, Posi in all his infinite patience would never do something like that!positron_ wrote:I've thrown tools on the ground and stormed off cursing at least twice! I give up...if I'm to do this by myself I need a tool.
There is a special pliers made for these rings, but you should be able to get by without them. I would have thought it was harder to get it out than back in. Once you get it started in the shifter bore sharp blows with a blunt tipped tool like a punch ought to get it moving. Tilt one end in first then compress the right and push the other end in. Curious, did you replace both shifter bushings?positron_ wrote:Can anyone tell me what they used to get the snap rings back on their shifter? I know I can use some needle nose pliers for the snap ring with the holes in it that goes on top but for the other ring without the holes what can I use or get for it? I went to the parts store and the snap ring pliers that they had are only good for the rings with the holes in them.
SNAP RING PLIERS for constant section rings? Not going to work.duffman1278 wrote:Their called SNAP RING PLIERS. I suggest getting them. They're inexpensive and make the job easier.
I thought about doing that too if I couldn't wedge them in!TheBigS_42 wrote:I did this last week with a buddy and believe me it was not fun. I also got frustrated after countless failed attempts. So finally I took it out of the car put it under my shoe and beat some sense into it in the form of bending it a bit. Now maybe this isnt ideal but by making the 2 tips a tiny bit closer together we were able to finally get it into place with 2 flat head screw drivers and some pliers. it doesn't fit as snug as it used to but it doesn't have enough room to come out and as much as I try there is no way for the shifter to come out so I am happy with it.
I'll keep trying!enterpricorp wrote:SNAP RING PLIERS for constant section rings? Not going to work.
I never had any trouble getting them back in the groove just get one started on an angle and muscle it in the groove. To get them out I just put a small pin punch in the bottom shifter guide bushings pin/keyways and pop it out of the groove.
I went ahead and got those pliers but seem to be no good for the holeless snap rings.duffman1278 wrote:Their called SNAP RING PLIERS. I suggest getting them. They're inexpensive and make the job easier.
That's because it's not a snap ring it's a "constant section ring" I don't think he knew what you were talking about before he posted.positron_ wrote:
Quote, originally posted by duffman1278 » Their called SNAP RING PLIERS. I suggest getting them. They're inexpensive and make the job easier. I went ahead and got those pliers but seem to be no good for the holeless snap rings.
exhsturbine wrote:i think if anyone here deserves to drive their car..... its you, ive been following this since you started....... so why havent you finished? : )
make no mistake.... good job!
supreamS14 wrote:Thanks for the info again! I will add some WD40 to the pedal and spring tomorrow.positron_ wrote: either I'm out of practice driving a manual or that stage 2 clutch is way to stiff for me. QUOTE]
I thought my stage 2 exedy clutch was too stiff as well. The clutch pedal probable just needs a little wd40 on the spring and moving parts. Well 1 day my girl was driving and the crappy clutch pedal tack welds broke making the clutch pedal useless(she drives it like a granny)! we were in the middle of the road like what are we gonna do? I couldn't get it in gear with the car on. I did a auto to Manuel swap so I could start it when in gear. I turned the car off, I put it in first and cranked it, the car jumped and started to go in first. I then remembered the sr has a synchromesh transmission. I took it to 2500rpm, pulled it out of 1st gear and it slipped right into 2nd without the clutch. I got it home, pulled the pedal( the little crappy tack welds make me wander WTF did nissan do?), Took it to a muffler shop, Payed $5 for them to weld that crap the right way, went home, painted it so it wont rust, hit it with wd40, slapped it back in there, now it feels solid, smooth and it don't feel as hard to push the pedal.
Yet another leak I might add. This time it's oil coming from the turbo line banjo bolt. I'll have to get out the wrench and tighten that. It seems that all my leaks appear to be from stuff not being tightened enough. I'm going to have to be extra vigilant from now on when it comes to stuff that I don't tighten with a torque wrench. I also think I need to tighten the banjo and bolt on the P/S pump. The coolant leaks on the temp sensor bung and firewall fixed, the gas coming from the fuel gauge fixed(if you get one of these, make sure you take it apart, put teflon tape on the threads and tighten back). I guess it could be worse because aside from these minor leaks, everything appears to be fine. I will be doing a leakdown/compression test ASAP to see if my numbers match JSA's. Also, the idle started off at almost 2000 but after the car ran for awhile it dropped and leveled off at 1000. I'm gonna look more into this but if anyone has any info on that it would be greatly appreciated.
