My S13 SR20DET Prep
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
Kalypso123 wrote:you removed your crank pulley and replaced the front main seal, but I cant find that post anymore.
where is it?
It's on the first or second page of the thread.
I WE TODD ED
Car: '90 & '91 S13
Thanks man. That is just what I needed.
Apparently the A/C brackets on the redtop sr's are different than the A/C brackets on the blacktop sr's. I just wanted to see a redtop bracket so I could confirm that.
Thanks again
positron1
Hummm, I didn't know that either.
Kalypso
thanks saf,
im trying to remove my rear rotor, but it seems rusted shut... I read your rotor swap guide and its nice.
I would ask questions but by the time you post back ill have it off
positron1
Did you get that rotor off?
Kalypso
not yet, I have been wailing at it with the rubber mallet.I need another strategy
but the front hubs are off tho, and sporting a fresh new set of 350z studs.
I WE TODD ED
Car: '90 & '91 S13
Hey Positron,
Are you going to keep A/C?If not, would you sell me your A/C compressor bracket?
Thanks
Kalypso
I got the rear rotors offand I added the info to your brake rotor thread for posterity.
the ichiba rear hubs are at a machine shop know
the holes for the studs are 7/100's of an inch too small so they are going to be slightly overboard by that much and then ill press the new studs in myself.
Modified by Kalypso123 at 4:38 AM 6/12/2008
positron1
Cool man, you're gonna enjoy that new setup!
positron1
I WE TODD ED wrote:Hey Positron,
Thanks
PM sent!
Kalypso
your threads made it possible - question for you,
on the right circle - the hose that leaves the valve cover, what exactly does that hose do?
I see if going to the box on the left - I am wondering the benefits of this setup
positron1
I'm not exactly sure what it does but the pics I've seen either have that hose leaving the T on the valve cover going to that plastic intake or to a catch can.
Kalypso
its quite the mysteryhere there is a small filter, Ive seen a few cars doing that.
i wanted to try it, but I would like to understand how it benefitsill search some more
inkslingers13
Car: 1985 Corolla Gt-S
i have mine hooked up to a catch can, it goes front of the t-fitting to one side of the catch can, then the other side of the catch can to my intake. i wouldn't run a breather filter on the end of that fitting, oil will leak out of it and its in no way going to benefit your motor. put a breather filter on top of the catch can. hope this helps
inkslingers13
Kalypso123 wrote:your threads made it possible - question for you,
and im pretty sure that the PVC valve from the valve cover goes straight into the intake for a vacuum source. not to the catch can...
Kalypso
how does a breather filter benefit
inkslingers13
it doesn't, on the catch can it just would make everything flow a bit better. the way its hooked up on the FLASHY sr is bad. look up how to hook up a catch can on here. it explains how running it like that is bad
positron1
I think I'm gonna run mine with a hose from the T to the catch can and a hose from the catch can to the plastic intake hose/adapter.
Kalypso
inkslingers13 wrote:it doesn't, on the catch can it just would make everything flow a bit better. the way its hooked up on the FLASHY sr is bad. look up how to hook up a catch can on here. it explains how running it like that is bad
thanks, I will
I need to learn about vacuum lines and the science behind them also.I have a BOV and a manual boost controler that I dont know how to hook up I want to sort all of that out.
inkslingers13
positron_ wrote:I think I'm gonna run mine with a hose from the T to the catch can and a hose from the catch can to the plastic intake hose/adapter.
thats exactly what you should do
positron1
Kalypso123 wrote:
thanks, I will
Ditto!
inkslingers13
positron_ wrote:Ditto!
Kalypso
Ok so you are going to 1 and it seems like the first post goes to 2
positron1
I'm serious...I have no idea what I'm doing!
positron1
Kalypso123 wrote:Ok so you are going to 1 and it seems like the first post goes to 2
The hose at the end of the arrow on 2 connects to the cold pipe right?
callmeweezy724
Car: 1990 240sx w/s13 blacktop swap, 1986 e30 325e 4dr 5spd,1997 infiniti Q45
yea thats correct..it connects to the pipe coming out of the side of the cold pipe..
positron1
I finally got a exhaust manifold and turbo outlet. I did some research and narrowed my decision to a Tomei Extreme manifold and Circuit Sports outlet but decided to scrap those plans and get those items when I upgrade to a new T28 and go front mount. For the stock turbo I just went with the best "bang for the buck" setup.
Tools needed:Socket wrenchSocket extension13mm socket14mm socket15mm socketNeedlenose pliersScrewdriverHammer(you'll see why later)Anti-seizeThreadlockerRazorblade
I got a setup in the other day.Megan Racing turbo manifold.Megan Racing turbo outlet.OEM T25 S13 TurboOEM multilayer metal exhaust manifold gasket part#:14036-75F00.OEM metal turbo inlet gasket part#:14415-17M00.OEM metal turbo outlet gasket part#:14445-26E00.OEM turbo locking plates part#:14495-40P10.OEM exhaust manifold washer part#:14037-42L02.OEM exhaust manifold nut part#:08912-8401AThe manifold came with new studs and hardware, like a brace of some sort. I went ahead and installed the brace...and seated the studs into place. Don't forget to use some anti-seize on the studs all around for the future if need be.Take the turbo inlet gasket...and place it on.I had to back it off a bit so that I would have room to put the locking tabs and nuts on.Like so.The manifold came with some nuts but they have flared ends so they pretty much covered the tabs on the locking plates so I used a set of M8-1,25 from the parts store instead. These are just like the stock nuts that I originally removed from the turbo and they don't have flared ends so you can fold the tabs over these nuts...can I say that?!While I was at it I decided to use some threadlocker as well because I had been reading a lot of threads about how these have a tendency to back off because of all the pressure from the turbo.Examples......I put the nuts on next. Space is tight so some of them are pretty tricky to get on unless you've got those little monkey hands.To get one of the nuts near the top of the turbo inlet on, I had to remove the water line for extra space.
Next, I tightened and torqued to 16-22ft.lbs.Use a set of needlenose pliers to fold the locking tabs over the nuts.Like so.
The nut on the inlet side was hard to get to with the pliers so I just used a screwdriver and a hammer to bend the tab on this one. This is where the hammer comes into play. The manifold is mounted to the turbo so now you can install it on the block.Exhaust ports.I had some old gasket still on the ports so I used a razorblade to remove it and clean the area before I placed my manifold gasket on.Take the exhaust manifold gasket...and place it on.Take the turbo and mount it on the block.Break out your cleanin' gloves and lube up the studs with some anti-seize before you put the hardware on. This stuff STINKS!!!!Place your exhaust washers and nuts on.From here you need to break out the FSM(factory service manual) because the nuts need to be tightened in a specific order.Tighten and torque to 27-35ft.lbs...and the manifold/turbo is mounted.Now on to the turbo lines.I started with the water line.On a S13 SR it will connect here. On a S14/S15 SR, it connects to the water neck unless you get a S14/S15 water neck and use it on a S13 engine...you confused yet?Use a screwdriver to loosen the fitting...and place it on the hardline here. Tighten it back with the screwdriver.Water line.I moved to the next water line.Take the banjo fitting off, the two crush washers that should be supplied and the stock banjo bolt. Like my new gloves, hobo style FTMFW!Put two crushers on both sides of the banjo bolt and install.Tighten and torque to 14-23ft.lbs.Lastly, the oil outlet line.Remove the fitting and the crush washer.Place it on the block...tighten and torque to 14-23ft.lbs.Almost complete!I can't install the turbo outlet yet because the people I ordered it from forgot to pack in the hardware(studs) so I'll have to wait on that.
I also don't have a O2 sensor or adapter yet.
TO BE CONTINUED...
Modified by positron_ at 1:36 PM 6/13/2008
inkslingers13
looking really nice man! how long till she goes in?
Kalypso
that is insightful
ill get a t28 or a gt28rs and this is a useful demo for the install.
Kalypso
so red box on the left is actually an oil catch can!?
thats cool. and it has a breather valve going to the cold pipe... that works
