My S13 SR20DET Prep
surge s14
Car: C5 Corvette,Porsche Cayenne S,F-150, SrPowerdMotorStand
Very nice job on the polishing job what kind of grit was it that you used?
this thread is very informative i will be refrying back to this myself
mRodiek
Car: Stock Hatch
just spent 2hours reading through this entire threadbest 2 hours ive ever spent a forum!!i know everyones tellin you this but great work!ill be checkin to see how its goin!
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
surge s14 wrote:Very nice job on the polishing job what kind of grit was it that you used?
The block says medium.
positron1
I got a set of spark plugs in today, here's what I did.
Tools needed:Socket wrenchSpark plug extension16mm spark plug socket10mm socketCanned-airSpark plug gapper
Before I got serious about doing a SR swap I called myself buying up parts for the intended swap even before getting the engine....big mistake. I did no research, didn't know exactly what I needed and wound up with a couple of useless parts so anyone who plans on doing this who doesn't have a good understanding of auto mechanics, aka "shadetree mechanic" like me, make sure you do your research so you don't waste time and money on parts that you don't need. Because of my impatience....I now have two sets of plugs one of which is completely useless to me.BKR6EIX Stock#:6418-stock boost. Heat range=6BKR7EIX-Mild hp. Heat range=7BKR8EIX-Heavily modified, high hp. Heat range=8I'm planning to run a stock boost, stock engine setup so this is the set that I need. I got this set from FRSport.com and they come pre-gapped for a plug and play install.This is the set that I bought before. Came to find out that they are not what I'll need and they are gapped to .040. BKR5EIX-11 Stock#:5464????? Let's get started. Get a allen wrench to remove the spark plug/coil pack cover. There are six allen head bolts.Use a 10mm socket or a screwdriver to remove the coilpack bolts from the valve cover.Pull the coilpacks out one at a time. I think some people disconnect the harnesses from the coilpacks before pulling them.You can see the plugs deep down in the block.Take a can of compressed air and blow out the well to remove any debris that could get into the chamber once you take out your plugs.16mm spark plug socket and spark plug extension.Take your spark plug socket...and place it in the well.Remove the spark plug.Pull it out. Remove all four plugs.New plugs versus old plugs. I looked it up but I still can't judge the condition of these pulled plugs. From what I read they seem to be normal or maybe carbon fouled...I can't tell...anyone? Here's the breakdown.
NORMAL PLUG-Light tan or gray deposits on the firing tip.CARBON FOULED PLUG-Identified by soft, sooty black deposits, may indicate an improperly tuned vehicle. Check the air cleaner, ignition components and engine control system.PHYSICALLY DAMAGED PLUG-May be evidence of severe detonation in that cylinder. Continued detonation could not only damage that cylinder but the engine as well.OIL FOULED PLUG-Indicates an engine with worn piston rings and or bad valve seals allowing excessive oil to enter the chamber.EXTREMELY GAPPED DISTORTED PLUG-Has been left in the chamber for too long as indicated by an extreme gap. These could cause misfiring and stumbling accompanied by a noticeable lack of power.
Take the new plugs and insert it into the socket.In order to avoid crossthreading them I seated them by hand instead of using the socket. You can feel when they are properly threaded better this way. Once you get them in, use the socket to tighten them.Torque the plugs to 14-22ft.lbs.Installed.Install the other plugs the same way, reinstall your coilpacks and your spark plug/coil pack cover.
If you have to manually gap your plugs then you can do so with a spark plug gapping tool. You can get them at the parts store for like a buck.Spark plug gapping tool...also useful to check gapping.Like I said before, these came pre-gapped to .030 but I checked just in case and they were.I thought it was cool that these old plugs were NISMO so I decided to keep them. I even cleaned one up and made a keychain out of it.
Yulaw
Car: 93 S13 240SX HB
This is one of the best build threads ever. You cover everything from bolts to tune-ups. You're build thread is like an sr guide for me lol. I also have altima fans and am waiting for my koyo radiator to mount them to. Keep up the good work!
duffman1278
Car: 89 240sx Hatch, the wildcats!
Good stuff, but as for torquing down the spark plugs, did you take into consideration the length of the extension? Usually if you add an extension the amount of torque you need goes down, depending on length. Just letting you know, and others so no one over torques their spark plugs.
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
The torque is only increased across the lever arm of the torque wrench if you use a breaker bar or something as an extension to the torque wrench itself. IIRC extensions after the center of rotation have little to no effect on the torque of what you are tightening.
positron1
Yeah I was worried about torquing those things. I haven't torqued mine in yet just got them in snug. I just included the torque specs because they are in the FSM.
duffman1278
redtop91 wrote:The torque is only increased across the lever arm of the torque wrench if you use a breaker bar or something as an extension to the torque wrench itself. IIRC extensions after the center of rotation have little to no effect on the torque of what you are tightening.
Yea thats what it was, mybad torque is F x d, force is perpendicular to distance, whoops.
Modified by duffman1278 at 7:44 PM 4/26/2008
positron1
While I had my fans broken down into pieces I thought this would be the best time to experiment with the shroud and see how I could mount it best to the radiator. These modifications were made with the purpose of using the Altima fans on a Koyo Aluminum radiator. Keep in mind that this is a total ghetto-fab job. It works but don't look so good.
Tools needed:10mm bolts10mm nutsSmall metal bracket(about an inch in length)DrillZiptiesKnife/blade/razorSandpaper or a sanding block(medium grit)
I was able to nab a set of Altima fans for use in my swap but the problem is that they don't exactly mount up properly to the Koyo/SR swap unless you modify. Untouched, the fans only line up with the top left mounting point on the Koyo and even then they aren't flat against the rad because of being blocked by the lower portion of the fan shroud sitting on the lower rad outlet and the A/C condenser brackets. I already explained earlier what I had to modify on the lower portion of the fan shroud in order to get the fans to sit flush against the radiator so now I'll go into detail on what I did to get them properly mounted to the Koyo. I was originally just going to use the Permacool fan mounting kit that I had with the zipties but I was informed by homeslicej2 that because of the wieght of these fans, that would destroy the radiator fins. It's just too heavy to be mounted in that fashion, much heavier than the Permacool. As you can see here the Altima fans cover the entire surface area of the radiator.They even over lap a bit on the left....and on the right side but that's not a problem.Here are the four points of mounting that I used. This is the upper left side, this is the only mounting point that lined up to the rad mounts.Just use one 10mm bolt and a small spacer if your bolt is too long to take out the slack.For the upper left side the mounting point is about a half inch away from the mounting point so what I did was...Take a one inch piece of metal and line it up to the rad mount and the fan mount...mark two spots on it for where the holes need to be drilled like so...and use a drill to make the holes in the metal. I went back and cut off the excess metal...well, I didn't actually cut it because I didn't have a tool so I just bent it back and forth with a set of pliers until it snapped off and then I sanded the edges smooth.I was able to put the bracket on the rad and the fan mounts diagonally. I used a 10mm bolt and nut on the fan shroud and I used a 10mm bolt on the rad mount with a spacer for the slack.Front shot.Top shot. Like I said GHETTO FABULOUSNESS!!!! Bolts not threaded in all the way but that's because I'm not ready to mount it. I still have to put the fans and motors back in....but it works!
While I was doing this I ran into a small problem. The bolt didn't line up straight with the rad mount because the side of the mount on the fan shroud was in contact with the bolt head pushing it to the side.This was easily fixed by just cutting a small wafer thin piece of plastic off the shroud here and sanding it down smooth thus giving the bolt head plenty of space to be threaded in to the rad. I still need to work on that because it just looks bad!On the lower left side as I explained earlier in the thread, I just cut a small section off here and sanded it down to sit flush. This needs to be worked on too...even'er out!And on the lower right side I cut a thin section off so the shroud could fit above the lower radiator outlet.
FOR MOUNTING THE BOTTOM OF THE FAN SHROUD I DID THE FOLLOWING.Trusty zipties. I figured that since the top of the fan is bolted in nice and tight then I could get away with zips on the bottom.I'm going to run two to three zipties per side throught the holes in the A/C condensor mounts on the bottom of the Koyo...and around the fan shroud like so.Tie them off and cut the excess.
I think that this could work unless the heat takes out the zipties so if anyone has another idea here let me know.Before I put the fans and motors back into the shroud I decided to work on those cut spots, clean it some more and lay a coat of Krylon fusion on to give it a refresh look.
This stuff bond pretty good to plastic but the extreme heat will soon take care of that yes....I gave it a shot! Now for the wiring and a fan controller.
TO BE CONTINUED
positron1
Man you guys know your stuff! Shoutout to duffman, redtop, hijacker, homeslicej2, d!ck, mrzabala, idahotuner, slideways and you other tech savvy gurus that I might have missed!
codyace
Car: S14 w/redtop
I'm really perplexed as to how that fan install has 'kicked your butt'.
All youneed to do is enlarge/relocate the top to holes to line up, and trim the bottom as nessecery.
For those with A/C on their cars, more needs to be trimed on either side.
Maybe If I'm bored today I'll snap a pic, but you can't tell mine aren't stock at all...and I love that
2 other things:
That torque stick you have is not accurate, get a click style
That spark plug gapper isn't very accurate either. Now on a 300ish hp car it may not matter, but your best bet is to buy a valve adjustment tool, and to use that
positron1
Noted.
topnotchg
Car: 2005 G35 coupe
looks clean bro
SR20phantom
Car: 1995 Nissan Altima SE
Awesome thread!!!
positron1
I took the throwout bearing off my clutch today and when I removed the fork this came apart. I know nothing of the pivot ball so should I be worried here and what are my best options for a replacement? Will a KA24DE pivot ball work or should I just get one from SPL, Nismo, etc?
duffman1278
I think FRsports, Enjuku, Phase2motor, and west covina nissan all sell that ball. Nismo makes one for it thats why. Its called a Pivot.http://phase2motorsports.store....html
tiger
wow you're pretty lucky that thing broke ... instead of while you were driving, it happened to me and was a nightmare. I'm sure you would have replaced it anyway. you're doing a great job, i love this thread! hah!
positron1
It must have already had a crack in it and been on it's way out so I guess I lucked out on that one so to speak.
zismo02
Car: S14
Nice build!!!
playbass311
Car: 1991 240sx
Really awesome thread man, I just sat down and read all 6 pages of it, haha. You're getting me pretty stoked, cause I'm pulling my motor this summer and rebuilding, now I'm super excited for it cause of this thread.
positron1
Thanks for the info and the comments people!
240sxHitman
Car: Boosted '91 240sx
Im replacing the pivot ball along with the throwout bearing and pilot. I just feel its better to do it now then later on. like the other guy said its better yours broke now. i plan on buying the nismo pivot around the same time i get my clutch/flywheel
lol plus after seeing all your updates i think its time to update my post. ive just been getting a bunch of parts in tho
i vote once this is done and ur motor is in and running...... i say sticky!!!
positron1
I got some parts in today for my transmission.
Tools needed: Rubber malletBlock of wood/small hammer
I read that you have to remove the SR dust collar and transfer a KA dust collar to the SR transmission in order to fit the OEM or aftermarket driveshafts on the SR transmission. I banged up my KA's dust collar trying to pry it off so I got a new one to replace it.Transmission dust collar part#:32135-97L00.They say use a block of wood but I didn't have one so I just used this small hammer and a rubber mallet. Place whatever you plan to use against the dust collar, whack it...and it comes off like so.The SR dust collar on the left is quite noticeably bigger than the KA dust collar on the right.Wipe the area down.Put your KA dust collar in and tap it in place.And you are done.
positron1
I swapped out the clutch slave cylinder today. I also swapped out my torn slave cylinder dust collar.
Tools needed:Socket wrench12mm socket14mm wrench
Slave cylinder dust collar Part#:30542-01S00.Torn slave cylinder dust collar.To remove it just grab a corner and pull.New vs. old.Take an opportunity to clean the area...and put your new dust collar into place.
Now on to the slave cylinderUse a 12mm socket to remove the two bolts holding the slave cylinder in.OEM slave cylinder and Project Nissan stainless steel clutch line.Crush washer for the clutch line. Part#:46237-S13001 Remove the rubber stopper from the slave unit.Use a 14mm wrench to put the clutch line in the cylinder. Got these bolts from Courtesy Nissan, Part#:08121-S13003, but you can also use bolts from the parts store M10-1,50X20MM, the same bolts you can use for the motor mount brackets.Use your socket wrench to put the new cylinder back onto the transmission and torque to 22-30ft.lbs.Finished.
TO BE CONTINUED...
P.S.That rubber stopper on your new clutch slave cylinder is the perfect size to use for blocking that small port on the bottom of the throttlebody that you won't be using.
Modified by positronone at 1:39 PM 5/1/2008
positron1
While I was ordering some stuff from Courtesy I took a browse through the clip section for the wiring and there are dozens of different clips for this car. I took a chance and ordered one that looked close to what I needed and it turned out to be the exact one. I cut these harness clips when I removed my wiring harness from the engine when I first got it and was just going to use zipties in their place but I found these instead.Wiring harness clip Part#:24222-S13007 You can use them here on the fuel rail for the injector harnesses.These zipties have a clip on them so you can clip them in the holes on the brackets.And here on the those two clips on the front of the engine for the MAF/PS/CAS part of the wiring harness that runs across the front.
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
Posi, some members (clawhammer comes to mind) have had this cover assembly break on the them where the collar attaches at the plate. I recommend that you go ahead and replace it, the front oil seal, and gasket (all circled in red above) while you have the trans out of the car and off the motor. Replace the rear main trans seal too. Midway parts team or Courtesy Nissan can give you good prices (before shipping) or just take the part numbers into your local dealer. The seals are $8-15 each, the plate is about $40, the gasket is about $8 too. Worth it IMO considering you'll have to drop the transmission out of the car if it breaks or the front seal starts leaking.
positron1
I decided to see how difficult it would be to replace the gaskets on my transmission while I had the chance so I removed some parts to check the condition of the gaskets.
Tools needed:Socket wrenchSocket extension12mm socket17mm socket
I had a broken clutch pivot ball so I started by removing that.All you need is a 17mm deepwell socket to remove it.
Next, I decided to check out the front transmission seal and the transmission front cover assembly.Use a 12mm socket to remove 5 bolts here...and the front cover assembly comes off.The seals look fine but if I do decide to replace them does anyone know how I can get them off because there is no where to grab at them like the other seals. I searched but couldn't come up with anything.The front cover...and gasket.There's also a O-ring on the underside.For the gearbox you need a 12mm socket...to remove 6 bolts and off it comes.Underside shot.Inside shot, really interesting to see the inside of the transmission which is another reason why I decided to check this stuff out.Also going to replace this gasket.Finally I will also replace the rear transmission seal.
PARTS ON THE WAY TO BE CONTINUED......
240sxHitman
Updates looking good positronone....... keep em coming
positron1
I attempted to put my power steering pump on today.
Tools needed: Socket wrenchSocket extension12mm socket14mm socketOld sock/ragRubber mallet...you'll see why later.
I originally received a HICAS P/S pump with this engine set but I don't have HICAS on my car. I could have used it anyway because I found out that you can easily modify a HICAS pump to non-HICAS status. I also got a set of lightweight pullies to use on this engine and for the life of me, I can't figure out how you could remove the pulley from a HICAS pump as it's not held on with a nut like the other pumps for the SR and KA.How do you remove this pulley?????I did read how you could use a KA24DE pump with a non-HICAS SR pump bracket though so after tracking one down from a forum member I attempted to put this setup together.As you can see here the SR non-HICAS and HICAS pump brackets are slightly different.
The non-HICAS SR bracket on the left is considerably larger than the non-HICAS bracket at the pump mounting point as you can see here.The KA24DE pump with the SR non-HICAS bracket...fits perfectly.Here is where I tried to mount the KA24DE P/S pump on the HICAS bracket...it's too small.
Now it's time to put the pulley on the pump.If you broke your pump down like I did, make sure you put all brackets back on. This one goes on the rear of the pump...like so. It has a slot for the tab on the banjo line part of your P/S pressure hose.I went ahead and put the pulley on the pump, this is where the socket extension and old sock came into play.Since the pulley will spin, you will need some way to get some leverage in order to tighten and torque the nut down when you install the pulley.I took a socket extension and in order to keep the extension from damaging the pulley by rubbing up against it, I put something soft around the extension.Stick the extension through one of the holes in the P/S pulley and you can use your foot to hold the pulley steady while you tighten and torque it to 40-50ft.lbs.Done!Next, you will need to mount the P/S bracket back on the block here.Use a 14mm socket for the three bolts here and torque to 33-44ft.lbs. If you managed to mix up some of your bolts like I did then the bolts that you use for this have 7 on the head.Next, take the tensioner bracket...and use a 12mm socket to put two bolts here. If you don't use the OEM bolts you can substitute M8-1,25X20MM from the parts store. Torque the bolts to 12-16ft.lbs.The extra long bolt that you will use to mount the P/S pump to the bracket has 7B on the head, you can't make it out in this pic but that's what it says.Spin one of the holes in the pulley and you can insert the bolt through it and into the bracket. Use a 14mm socket to tighten the bolt...and torque to 23-31ft.lbs.Am I finished you ask? Painfully no!It was at this point that I realized that I messed up and left a part off. This part that the tensioner bracket bolts connect to. Without this part on the P/S pump you can't adjust the tension on the P/S belts...doh! I had to take the pump back off and remove the pulley. After taking the nut off the pulley it's kind of hard to pull the pulley back off the pump so just grab a rubber mallet and whack the back of the pulley and it comes off quite easily without damaging the pulley.Take the bracket...put it on like so and bolt it down. Torque the bolts to 10-13ft.lbs.
Sadly after doing this I realized that the KA pump with the SR bracket was not going to work at least not the way I thought it would.I mounted the pump on the P/S bracket and as you can see here the pump tensioner is no where near the bracket tensioner.Not even close.As for the pulley, it won't work either.It makes contact...and it's not even close to halfway being threaded. I even broke out the OEM pulley and it's even wider than the Greddy unit so no go there.KA P/S pump with SR bracket=FAIL
Unless someone sees something that I'm just not getting then I'm gonna track down a SR P/S pump to finish this up.
TO BE CONTINUED.......
