The FSM didn't specify exactly what kind to use, it just said "Genuine liquid gasket or an equivalent" and that gasket hanging out the sides of the components can easily be pulled off at anytime. Do you mean the intake manifold brace?codyace wrote:no offense, but why in the world are you using orange silicone!
1. It's not nearly as good as ultra gray (which btw: it's what Nissan recommneds)
2. it looks ganky as hell all over, whereas gray can blend in.
Also: Take that silly factory brace off...talk about getting in the way!
Cody, you really should give the Toyota crankcase sealant a try. You'll completely forget all about permatex after that. It's black, and it holds better than any gasket maker I have ever messed with.codyace wrote:no offense, but why in the world are you using orange silicone!
no room in there and awkward angles.duffman1278 wrote:...One I'll mention to you now since your motor is out is if you plan on installing an oil pressure gauge, install the sending unit NOW, while the motors out because it was so lame to work under the car just to get access to the oil pressure sensor area.
Good to hear on the brace! As far as the oil pressure gauge goes, yeah I was going to put one on so thanks for the heads-up on that one!duffman1278 wrote:Don't even sweat that brace on the intake manifold, its really easy to take off and put on when the motors in, trust me, I just did this like 3 weeks ago. Took my like 5 minutes, mostly because you have to get under the car to take off the bolts on the bottom.
Thanks bro and I'll sit back and let the pros answer that question. I basically tried to do all the small parts that I could, belts, fluids, spark and such. Clean it up so it'll be easier to spot any leaks or problems after the startup.I WE TODD ED wrote:Excellent thread man! Kudos to you. I am definitely going to use this as a guide to replace some stuff on my sr while it's just laying around.
Quick question: What would be the major and most important things to replace on my engine? (besides belts and fluids)
Thanks and keep up the good work
Do you mean that ultra black? Question, do you guys think I should get this other type of liquid gasket and redo my gaskets?Hijacker wrote:Cody, you really should give the Toyota crankcase sealant a try. You'll completely forget all about permatex after that. It's black, and it holds better than any gasket maker I have ever messed with.
Point noted! I'll keep that in mind for my next build (which may end up being a KA...yuck hehe)Hijacker wrote:
Toyota <> Ultra Black. He just mentioned it was black.positronone wrote:Do you mean that ultra black? Question, do you guys think I should get this other type of liquid gasket and redo my gaskets?
M8-1,25. I just got some the other day.240sxHitman wrote:Good DIY on those fans! definitely gonna be back looking ova all this if i get my hands them also.
by the way would u know the size nut that would screw on to the bolt where the exhaust manifold and turbo bolt together.
