Go back and get the "free" step/tray that they should have to get it up high enough to be tight. You could have them check it at the same time.louiegz wrote:Well, this weekend I put a new Optima battery in my Q and it starts fine. I did it myself because the wait was too long at the Pep Boys for them to install it. One bad thing about the Optima is that it's too short. I ran out of thread on the tie downs so I couldn't secure the battery down tight. I have to get shorter tie down. The bad part is I didn't have my alternator checked, so I have to get that done. Is there any way of checking it myself, or should I just go back?
Modified by louiegz at 10:16 AM 6/27/2005
I e-mailed Optima, and they said the red top was model 34 and the yellow top was D34/78. I got the red top. We'll see how it works in the long term.qship96 wrote:researched Optima batteries over the weekend,couldnt find the proper sixe{group 27},do they make the correct size for the 90-96 q?
Good tip. I did your test last night and it seems that the alternator is fine. The dome light dimmed for a fraction of a second and went back to full brightness. This is good because I wasn't looking forward to having to change my alternator.BobE wrote:Two quick easy ways to verify the alt is working.
Dirt simple. 1) start car.2) turn on interior lite and look at it as U do step 3.3) switch the headlites on, U're looking for the interior lite to dim for a fraction of a second then return to the original brightness. If it stays dimmer the alt is bad!4) switch headlites off, if the interior lite gets brighter the alt is bad!
