breadbox »
https://forums.nicoclub.com/breadbox-u49113.html
Tue Nov 03, 2009 12:39 pm
well, wiki says"
In 1979.5 and 1980, models were powered by Datsun's 2.0L carbureted L20B engine, but soon after switched to the Nissan Z engine line, In the Middle East it was powered by Datsun's 1.8L carbureted L18 engine.
The 1981-1982 models used the Z22 carbureted 2.2L engine and an optional SD22 Diesel.
In mid-1983 Nissan introduced the Z24 2.4 Liter 8 spark plugs 4 cylinder motor, it produces 103 hp (77 kW), Z20 2.0 Liter and the SD25 Diesel; this happened at the same time that the 720 series was marketed as a Nissan (the Datsun name, which had disappeared entirely after 1984, was now only seen below the Nissan name on the left corner of the tailgate).
In the American market the diesel engine was only available in the 2WD 720 (from 1982 to 1985). The Z24 was upgraded to Z24i fuel-injection (option) for the 1986 models. Additionally, some overseas markets received versions with the 1.5L J15, 1.6L J16 or 1.8L L18 carbureted engines. The 720 Series was never available with any of the Z22E or Z20E multi-port fuel injected engines. These engines are, however, easy to adapt and integrate into the chassis and can be found with the genuine appearance of being original equipment."
