My J30 VH45-T project
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
efeezie
Thought I would go ahead and post up some pics of my J30 build.
Plans for the car are 475ish whp, Q45 auto trans while also keeping AC/PS. The turbo is a 60mm T4 turbo.
Got the shell for free so its a perfect candidate.
Motor bolts right in with Q45 mounts rotated 180*
Alternator clearance is very tight. I might go back and notch the frame rail for added clearance. May not be necessary but it will make it easier to work on later.
Mega clearance between the oil pan and steering rack
Got the oil return bung welded in
Whipped up some BS manifolds. I absolutely HATE log manifolds but they will do for my goals.
And here is the intercooler Im gonna use along with the 18" sportmax wheels I got for the car.
sijoko
Car: Black 1994 Infiniti Q45 Turbo, Pearl White 2014 Maxima Sport
Cool! Glad to see another Turbo Infiniti being born. Your VH powered J is going to be very fast. How much boost are you planning on running?
I'll be heading down to OKC in a few weeks. It would be great to check out your car.
SuperHatch
Car: 96 TLC
Very cool swap, I can't wait to see how this turns out. Keep us updated!
Great fab work by the way
efeezie
Sijoko- I plan on running however much it takes to reach my goal. Its a smallish turbo for a V8 so I figure it will take about 8-10psi to get there. Let me know when you come down, Ill be more than happy to show you.
sijoko
I sent you an email.
NukeMM_45
Car: 93' Infiniti Q45
Looks like a great start. Nice exhaust work. Keep the pics coming.
jay-spec013
Where did you get these pipes from?
BACARDI_DWB
those are called weld-el's and can be found at a metal supply shop
jay-spec013
Thank you sir
efeezie
acestainless.com
kbflip02
Car: 1994 Infiniti J30
2006 Infiniti G35x
well my friend looks like u got started quicker than i...things are looking good...hopefully once me and the wifey get adjusted to having a baby ill be able to finish my R&D stage of the swap and actually get started...on a side note i have located the donor car i just have to get it to austin so craig can start pulling the motor and transmission...keep us updated definately...happy new years bro
Raxephon
Car: '04 RX8...for the moment...
What are you using as far as a drive shaft goes?
J30? Q45? Sections of both?
efeezie
No it'll be a 1 piece. I have a place here locally that can make me a drive shaft.
Kalypso
cool
T45
Car: King Kong powered Z32
Looks like a simple swap so far, no mount fab, no oil pan fab, sweet platform! What's the weight of the J?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
weighs about 3600 lbs but would probably drop a little with the VH45..
BoostFab
Car: S13cp, S13fb, S14z
very nice. looks like that engine was an upgrade option from the factory that Nissan left out.
Mettler
Car: HR31 GTS-8 coupe, VH41/45 Hybrid Transplant
Not in the leopard and j-ferie
efeezie
Been neglecting this project trying to finish the race car. I have since got the car running pretty good. Motor had good compression across and metal timing chain guides so thats a plus.
I did manage to get a little bit of fab work done however. Gotta love short route piping
Carl H
nice work, wish i had access to a tig.
Mettler
Yeah those are some nice welds :D
OUKNO
Car: 1990 Z32 NA, 1974 International Scout
excellent work sirI so hope to hear this thing works out marvelously with the turbo with factory compresionIt is great to see the way this thing fits in their, lucky bastard not to have to do all the fab work
PanzerAce
Car: '73 Datsun 240Z, N42 block L30, E88 head, Mikuni shorty manifold, triple Mikuni 44mm PHH carbs
What are you doing with regards to the intake upstream of the turbo? Maybe it's just me, but it looks like there is basically no room there.
efeezie
Thanks guys, I need to get a few more pics. I managed to use a R33 driveshaft I had kicking around. It was perfect in length, the only thing I had to do was make a bracket to bolt the carrier to. Works like a charm, know I just need to get some brakes on this thing
pazer- The picture is a little deceiving, there is enough room to fit filter in there.
OUKNO
PanzerAce wrote:What are you doing with regards to the intake upstream of the turbo? Maybe it's just me, but it looks like there is basically no room there.
Looks like this HKS would fit in there perfect
CrazyTrance
Car: 1991 Nissan 240sx - vh45de
Sick!! I like the single turbo, ive thought about that also, and that manifold is EXACTLY how i would have done it. Badass man.
Nealoc187
Car: 95 Maxima
Sorry for bringing this post back from the dead but I was just searching and found that you've apparently completed my current dream swap hah. Anyhow, if you're still in need of a filter there are a million odd K&N filter sizes that you don't normally see. I had a very short and squat K&N that looks like it is made for exactly your application, because my turbo to frame clearance was once just like yours (in a different car). It fit perfectly right on a T04S housing, was probably 6" in diameter, 4.0x" opening, and about 2" long.
Anyhow, how is your project coming along? I'm very seriously considering starting one myself in the near future.
efeezie
I havent had much time to give to the project but its alive and running. I'll update this thread when I can get back on the car.
Kalypso
looking nice
efeezie
Been awhile since I last updated this thread. Finally got the motivation to finish it. Few pics of the downpipe and exhaust. Exhaust is full 3" with magnaflow muffler
Went this route to save room for the AC
Actually got the car on the dyno and ending up making 380whp/420tq before the turbo died. Not a big deal, it was a freebie anyway. The goal is 450whp with the auto.
Its going off for paint this week. Soon as I get the car back I just need to clean up the interior, put the wheels on and slap a new turbo on it
Return to “VH45DE / VK45DE / VK56DE Forum”
