mwhite7x wrote:The check engine light does not work.. We have scanned about six times now.. We tried out the coil pack thing by putting my brother's coil packs in my car and it ran fine.. We fixed everything that our mechanic told us was wrong and there is still a misfire. So we are going to stick with the coil pack thing and see where that gets us.. I'm really torn between selling this car or just keeping it because we have put so much money into it
The check engine light doesn't work or you aren't getting any codes? If the bulb is burned out on the light, you'll still be getting codes when you scan it.
If you aren't getting any codes, how do you know it is misfiring? What exactly is the car doing? It is possible you may think it is misifing but it is something else entirely. If it is misfiring at all, you will get a misfire code.
