evildky wrote:70-71 used the E30 head, it had small valves and the smallest combustion chamber of any L6 head in the states and an externally llubricated cam
The E30 does have the smallest chambers at about 37CC, but was only available in Japan.The E31 head with the smallest a chambers at 42.4CC's. I've got one =D
The E30 actually had slightly smaller intake valves than the E31
evildky wrote:the E88 was found on 72-74, has the same small valves but a larger combustion chamber reducing the CR still externally lubricated cam
There's supposed to be 3 versions of the E88, one of which was only made for a few months, that one had a slightly different shaped combustion area and larger ports, but the ports had a choke point that if you revome by porting the head, open the ports up really nicely. I can tell you I've seen two. I had a regular E88 from my 72 engine, and I managed to get ahold of one of E88's that was only made for a few months.(still holding on to that one)
The E88 chambers are 44.7CC's
*Edit* the 260's E88 looks much different than the other 2 E88's, but is supposed to be the same CC's
evildky wrote:the P79, which has the larger valves
Actually the E31, E88, N33, and P50 heads have 42mm intake and 33mm exhaust valves.74 was the year they got bigger, the N42, N47, P81, P79, P90, and P99 all have 44mm intake, and 35mm exhaust valves.
evildky wrote:as for carbs, theey changed a lto as well, there are round tops in earlyu cars, 70-71, 72-73 got square tops, and the 74 got a reworked version of the flat tops in the beginning f the year but by the end of the year they were fuel injected
72 has the 3 screw round top SU's, and I think 73 did as well, but I'm not sure on the 73.
Btw, Evildky, I'm sorry for dissecting your post, I'm not doing it to be mean or anything like that. I just happen to have 5 different heads in my shop to choose from and have been doing research on them for the the last few weeks. So I had all the info on the heads handy.
Modified by DemonZ at 11:45 AM 6/3/2008
Modified by DemonZ at 12:21 PM 6/3/2008
