my engine is ticking/knocking? not sure.
crazys13hatch
Car: sr20det 240sx
i just put a new head on the block. i put brand new rod and main bearings (acl race bearings) about 150-200 miles ago. one thing i did though was put an old spark plug i had in the trunk cuz i broke one from my old head.
the car sounds perfect at idle like theres nothing wrong with it. after 2500 rpms it makes a ticking/knocking noise. could it be the old spark plug that i put on? could that cause a ticking/knocking noise? i also checked if a rocker arm fell off and it was totally fine.
correct me if im wrong but should a car be knocking at idle when the bearings are bad?
oh yeah, the ticking started on tuesday and it does not get worst and today is saturday. i hope i gave you guys enough info, thanks.
carmo
Car: 92 Accord, 90 Civic, 89 240sx
Is it a lower end knock or is it more like a valve train tick? Can you adjust valve lash?
gnr_70
Car: 1993 300 ZX Convertible MT
zerothread?id=377089
any ideas is appreciated.
