My DE-T build
2FAS240
Car: 1995 Nissan 240SX SE / 49' Chevy Stepside / 04 Tahoe
i will look into that nelson thanks! this build was supposed to take me a year haha i'm on the 3rd year now !! but i drove it around for 2 years after i built the motor just to break it in before boosting it (i only put 6 thousand miles on it in those 2 years though)
2FAS240
well ordered the Apexi NOIR exhaust looks to be exactly what i am looking for...
kind of landed on a minor/major setback... found wrist pin c-clips in my oil pan so i gotta tear the motor down quick and check out the cylinder walls and maybe have to get it bored out and a new set of pistons which would suck a** but i should have the rest of it tore down by tonight
2FAS240
THE GOODS CAME TODAY !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Garrett Twinscroll GT3582RFull-Race Twinscroll ManifoldFull-Race Downpipe
2FAS240
Cylinder 2Cylinder 4Cylinder 3
Daniel@Z1
Car: G35
That doesnt look good. If you need help with a good rebuild we have a great engine builder here at Z1motorsports
RideNslidE
Car: 1993 240 hatch the track and a 1993 240 vert DD
just a guess but did you not install the wrist pin clips...you'll only ever forget that once
Never mind i just read that you found one in your oil pan, that sucks man. To see an entire motor get jacked up from something so small is a shame. Were they the wrong ones or were they just not fully set.
the rest of that build is awesome, stuff looks real good.
Modified by RideNslidE at 5:03 PM 3/24/2010
2FAS240
that will barely set me back if someone can answer my question...
are the s13 ka24de block the same as the s14 ka24de block !?!??! if so i already have a new block
Chris28
Car: 92 s13 KA-T
Yes they are. The heads are different, but as far as I know the blocks are the same.
2FAS240
thats what i thought to...
can anyone confirm this for sure ??
nelson8708
Car: 1989 Nissan 240sx Fastback
1994 Acura Integra LS
They are the same. I dont have a s13 and s14 block laying next to each other to look but, i've never heard/read anything to suggest they are different.
-nelson
Daniel@Z1
Car: G35
The bottom ends are the same for s13 and s14
2FAS240
good deal well i just picked up another block. but i'm in Daytona Beach for the week so i will start putting it back together next week !
93 Chuki FB
Car: 1989 240sx coupe, EMUSA coilovers, 1 piece drive line, welded diff, S14 KA24DE swap, 10lb flywheel, Modern rims with 10mm spacers, rear sub frame spacers, steering rack spacers.
i have both a S14 and S13 blocks, and i looked and they are the exact same.
2FAS240
alrighty i'm back !! so i got a new block sent it to the machine shop got it bored .020 over a new set of arias pistons got it decked had them balance the whole rotating assembly took a month but i finally got it back from them 2 weeks ago and started putting it together again and this is whats been goin on !
this is what i have for gauges i just finished setting that up the other day
Block :)
Pistons and Rods :)
short block !
Full Race Manifold
My Kickin Set up !!!!
my battery relocation set up... took a while but what do you think ??
so this is where i am currently at as of posting this today...
ghx407
Car: 1993 240SX KA-T
me gusta
motoman399
Car: 98' wrecked (RHD coming soon) 240
that is a sweet manifold.
JDmisaac
Car: s13 coupe
05 scion xb
damn very nice build man
lets see numbers!
haha
what engine management you running?
2FAS240
AEM EMS :) already ordered it ! should be here this week i hope it was back ordered for like a week so we will see
JDmisaac
Car: s13 coupe
05 scion xb
hell yeah
i'mma see how my attempt goes for megasquirt.
2FAS240
so this is my Dual Walbro Setup... what are your thoughts???
motoman399
wow looks cool to me. what power are you going for? are you running larger fuel lines also? seems if you have the need for two fuel pumps then you would need like -6 or -8 AN lines also?? i could be totally wrong but just seems that way to me.
2FAS240
i'm shootin for the 600HP mark... at this time i don't have larger fuel lines installed but they are in the plans haha i will run all knew hard lines either this summer sometime or wait until winter... also i'm going to make a billet aluminum cap for the fuel tank so that i can use all AN lines and fittings
Agent
Car: 93 240sx SE Fastback
94 Celica GT Liftback
#3 ????
Damn you full race manifold!!! I gotta try to duplicate one of those since I lack the $1100, mind taking some pics for me?
enerj
Looks really great, especially the gauge and battery relocate install, plus the block. Did you figure out what was the problem with the cylinder wall scoring on the first build? Incorrect wrist pin clip install? What did the block work (cleaning boring decking etc) cost you if you don't mind?
Lastly I think motoman has a good point about the size of the lines coming from your two fuel pumps. You Y them into 1 line, what is the size of this final line? You could be seeing higher pressure here that your pumps have to fight against. Sure it'll be better than 1 pump but this setup may not be at 100% of what it's capable of depending on these lines.
:dblthumb:
GEO
Car: 95 240sx KA-T
:bigthumb:
Caveit77777
Car: 1996 240sx SE
Why don't you try using some quality NAME BRAND parts d!ck. / sarcasm
S14Kouki10
Car: 1997 240sx
updates?
2FAS240
he guys sorry!!! i didn't get any e-mails from your guys replies for some reason! there has been lots of progress in the past weeks
the block work cost me right around 400, and yes it was the incorrect wrist pins
it is still the stock hard line, i plan on re-doing all the lines and running -8 this winter and thats the reason i didn't modify the trunk lines.
EGR block off plate
Before
working on the fuel setup
Manifold!
and of course turbo!!
and thats where i am at as of about 2 hours ago :)
motoman399
2FAS240 wrote: Image
so two questions.
is that stainless tig? hard to tell from the pics.
and why did you do the pie cuts instead of a mandrel bent piece? looks good though.. car is gonna rip!
2FAS240
yep stainless tig... and did the pie cuts because it was kind of a wierd angle coming off of the full race downpipe and also to get a mandrel bend 3" stainless chunk it was another 70 bucks! plusit was kind of fun and a good learning experience... turned out pretty good for the first time i think
