rchboy »
https://forums.nicoclub.com/rchboy-u24649.html
Fri Aug 26, 2005 1:08 pm
well my motor starts, but will not rev past 2,000 rpm. i have an safc2 hooked up to it and im not getting much of a maf reading. i have tried settings ok 2in 5 out and 2 in 7 out, but does not reading does not go above 3% and 1.7-2 volts. I have tried a z32 maf and a maxima maf but symptoms stay the same. with safc disconnected runs the same. with maf discvonnected it runs a tad better. in any setup car idle fine and dies as soon as the throttle is touched.
i have a gt28rs turbo on it and dsm injectors, splitfire coil packs, and tomei fuel pump, aeroquip regualtor set around 43 psi. The ecu is showing code 34 which what what i have researched is knock sensor, but no other codes.
Any and all help is appreciated thank you gentlemen
