franticvike »
https://forums.nicoclub.com/franticvike-u226482.html
Sun Oct 20, 2013 8:53 pm
I just did this today. Not for any particular reason, buddy just spotted a higher trim cluster so we decided to swap it. Of course, I ended up grabbing a V6 cluster, so the tach isn't working properly, but that's a different problem [any advice on which is welcome] My truck is a 94 king cab 2wd k24, so maybe slight differences, but doubt it.
Should be two screws near the top of the instrumental cluster, those are obvious. Then pop the front plastic off the dash, One big piece all around the steering wheel, it's on with maybe 4 metal clips. I was ale to get it off no problem by pulling on it down and away for the left side, then I popped a flathead into the right side and it came off pretty easy. That should expose a couple more screws, just take those out. Once those are off, there's a plastic fascia that needs to come off. After that, work the cluster out slowly, and unclip the wiring harnesses as you can get at them.
Probably took me 20 minutes to get it out and back in.
Hope that helps
