240cp wrote:TotalD,
If you dont mind i have some questions about your turbo. You said it is a s374 with race cover.
1. What size is the compessor wheel, 74mm?
2. Is the turbine a t4 or t6 flange?
3. Can you tell me what center tag reads?
I know this sounds crazy but i have a borg turbo that looks identical to yours in every way exept my turbine housing is bigger. But my center tag classifies my turbo as a s400 series. I have measured mine and the compressor is 71mm inducer and the turbine is 96mm exducer. Thanks
My compressor wheel is 74mm, and the turbine is a t4 flange. Mine is classified as a s400 as well. The inducer is 74mm while my exducer is 83mm if im not mistaken. It has a 1.10 a/r and race cover option. Ill get the info off my center tag and reply once i get it.
