My 240 is running poorly, possible sensor? HELP
King Chilie
Car: 240sx, S13, 1993
Monte Carlo SS, 1985
Chevelle SS, 1968
Well let me break it down, im new to the nissan world, i've tried searching for answers, but if i am repeating already answered questions, please kindly point me in the right direction. I just recently purchased an S13 coupe, KA24DE, she ran fine when i got her, she started acting up one day after i took her to the car wash and hasn't got any better. The symptoms are; poor idle, when i go full throttle she bogs and slowly increases in rpm's, but if i hold the throttle 1/4 way it'll sputter and run up the rpm's a little faster. I did run my ecu for codes, got a code 12 (air velocity sensor) so i changed the MAF sensor, didn't help :confused: . I just want some help before i throw more money at someting that doesn't need replaced. I am mechanically inclined, but i haven't worked on any cars with computers :gotme , and now im remembering why, haha jk, but im trying to learn so bear with me. The reason i got this car is because my friend has one, and after i drove his i new i had to have one :chuckle: , so much fun to drive....when they're running right! So one nissan lover to another, please help me!
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
Take some sensor cleaner to the iat sensor. Also I would check wires and plugs.
King Chilie
Chevelle SS, 1968
I'm gonna run a compression test while I'm at it.
King Chilie
Chevelle SS, 1968
Ok, fixed one problem, apparently whoever owned it last didn't tighten the spark plugs very well hence causing some blowby, so for safe measure i replaced the plugs and now no more sputter :biggrin: , but it still bogs when i put my foot to the floor :confused: , so maybe tps sensor, maybe iat? Gonna check them today.
King Chilie
Chevelle SS, 1968
Well, simpler than what i thought i could've been. Number two spark plug wire was shot, got a new set coming in monday or tuesday. But were all fixed up for the most part!
