I have always noticed a slight gurgling in the heater core so I decided to burp the cooling system today. I parked car on neighbors driveway that is a 45 degree incline and set car at idle. I then removed the purge valve and radiator cap. I revved engine to 2000 rpm for a bit while sitting in the car I noticed the heater was not warm. Oh well... I got out screwed purge valve back in and topped off the radiator with a little bit of water.
I now noticed heater was not blowing hot air and observed fans were running non stop! so I drove around block and let her idle until I noticed the engine temperature gauge was at HOT
I pulled car immediately into the garage, opened hood and she was boiling! My coupe has sit all winter in the garage only being moved in and out and maybe a drive around the block....do you think I got a stuck thermostat?? or I induced more air in the cooling system???
how hard is to change a thermostate in this 3.5?? I work at a body shop so Im capable of doing it if its not BURIED under engine parts.
I am so pissed right now
please help!!!!!
