steve_rolfeca »
https://forums.nicoclub.com/steve-rolfeca-u210073.html
Thu Oct 16, 2014 7:28 am
Same problem here. 2011 Versa Hatch, gently driven, 40,000Km.
I've contacted Downey Nissan here in London, Ontario to see what they can do.
I've had zero complaints with this vehicle, except for a rather bizarre part failure that was covered under warranty:
At less than 20,000Km, I heard a loud, almost explosive bang from under the right front corner of the car while driving slowly through a parking lot. There were no further symptoms after the noise, except a slight, occasional "gronking" noise from that corner when making tight turns at low speed.
It turned out that the spring had a flaw in the steel, and had broken. The reason that the ride height, etc., didn't change, was because the break was right up at the very top of the spring, and wasn't in one of the active coils.
Given the excellent way the service department has treated me in the past, I'm hopeful that they can do something for me under a goodwill warranty.
