WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Fri Oct 31, 2003 9:31 am
If you get the generic MSD BTM, it doesn't increase the spark, but if you get the MSD6 BTM which is $350 you should be all set as far as spark goes.
Now as far as how much boost you can run. The BTM will pull out enough timing for your motor to fall on its face on setting 3. So Timing isn't the issue, fuel would be the shortfall.
If you start sputtering at higher RPMs at high boost levels, you know its time to upgrade your ignition. But I'd say your good till atleast 15 psi with a set of Iridium plugs and the BTM.
WD
