tyrannix »
https://forums.nicoclub.com/tyrannix-u27595.html
Mon Aug 15, 2005 8:39 pm
so, under normal conditions, the intake valve cover is venter into the plenum and teh exhaust cover is vented to right before or after the compressor with a pcv valve so it will let out the corrosive mix, but not when the boost is on?
does the block need any ventilation?
it would be great if a printed document *FSM :\* covered all of this... these are all things to know for engine reassembly
well, i have 1 catch can, so i should be good if i use a T fitting and vent both valve covers into the catch can, then into the plenum?
so , except for the oil, which the catch tank should take care of, i am liking the blow by setup
i should be good as far as oil residue goes if i mount the mafs on the FMIC output? shouldnt be any oil there anyway, should there? and it will have the colder, denser, more accurate reading and wont be affected by the BOV (right after the compressor, as normal)
