qdemn7 wrote:Newbie here, I just bought a 2008 Altima sedan (45k miles) with 100,000 bumper to bumper service policy. When I asked my salesman about Mobil 1 specifically, he said it might cause problems with rings, seals and other engine parts to prematurely break down.
I have heard this before from other non-Nissan people, concerning other car brands.
Can someone please comment on this?
qdemn7:
It doesn't sound like your salesman knows what he's talking about. The real issue is that cars with a lengthy history of continuous conventional oil use (a/k/a, dinosaur oil) is that conventional oil will "bake" as it breaks down, to form a sludge around engine (or oil pan) seals and thereby potentially conceal a leak that would otherwise lose oil continually while the engine is running (and sometimes even when the vehicle is at rest!). This, if I understand correctly, is a side-effect of conventional oil breakdown due to overheating at or near the site of the engine seal. As long as the conventional oil is replaced with similar conventional oil, the sludge remains intact and can prevent oil loss, and a leak from being discovered.
When you switch over a car such as this hypothetical one I've suggested, from conventional oil to synthetic oil, the synthetic oil can actually work to dissolve the baked-on sludge left behind by the conventional oil around engine seals, and a seal leak which was once protected by the broken-down baked-on dinosaur oil sludge can then be exposed, allowing oil to be lost. Synthetic oil has taken a bad rap for this phenomenon, when in fact, it is the fault of the conventional oil for concealing what might otherwise be a potentially catastrophic oil leak.
Every car is different. It's possible that at 45K miles, your car might have no problem with the switch over to synthetic (especially if you were to do an interim switch to a semi-synthetic product). It is also quite possible (depending on the maintenance history of the vehicle) that switching over to synthetic might expose a nasty oil leak that you might not be made aware of for a long time, if ever. I would proceed with caution, and if you decide to risk the conversion, be prepared for the worst.
I have read that 70K - 75K miles or so is the theoretical cutoff for even considering a switch to synthetic oil. If, however, you ever get your engine rebuilt, and you aren't switched over yet, it would be a prime opportunity to do so, as an engine rebuild should include getting the engine oil seals replaced.
Additionally, I have heard (don't know if it's true or not) that one shouldn't switch from conventional oil to synthetic oil, and then back to conventional oil. Makes sense to me, though.
-b-
