BBISHOPPCM wrote:Word on the street is it will void your warranty if they can prove the modification caused damage. Of course, anything that involves the exhaust from the manifold to just after the catalytic converter will likely affect your emissions warranty, and if the car were to catch fire as a result of an improper exhaust installation, this would void your warranty. Anything that involves nitrous oxide, head, internal components, or block modifications will void your warranty; installing a turbocharger will void the warranty. Then you also have to consider you have SEVERAL warranties; for instance, shaving the heads to increase compression will not void the warranty on your battery; installing a custom suspension will not void your drivetrain warranty... do you see my point?
Its called the Magnuson Moss Act. You can mod your car anyway you like, but you are voiding the original part completely. Also if your mods is what killed the car, then that too is a void.
ANYTHING that modifies the safety of the car, voids the entire warrenty, which includes lowering the car, Aftermarket steering wheel, Racing seats and harness. Non Factory big brake kits also void the warrenty simply because if you "upgrade" your brakes for far more abuse and for the "pretty" looks, and never use them properly, its a safety hazard. Most people think bigger is better when it comes to brakes, not true. Usually big brake kits on mild or stock cars significantly hurt performance.
