94RepoJ30t »
https://forums.nicoclub.com/94repoj30t-u124842.html
Sun Jan 25, 2009 5:57 pm
Great news...I was able to replace the fuel injector thanks to the PDF I downloaded from another post here on the NicoClub website. I took longer than it probably should have, but I learned the importance of tossing all of my WD-40 cans and replacing with PB Blaster. ;-)
As for the car, it runs SO MUCH BETTER! I cannot believe that all of that vibration was caused by the bad injector.
Now, for the not as good news...
When I tested another one of the car's injectors....it's Ohms reading came up 66??? That's not within the 10-14 range that I have heard indicates a healthy injector. However, the injector I replaced read nothing...no sign of resistance at all. Is my 66 Ohm injector headed South too???
Also, my CEL light comes on intermittently now... Usually at lower speeds or when my RPM's stay below 2,500 for an extended period of time. No vibrations or audible engine missing sounds, but the light does come on regularly. I eagerly await the CONSULT cable that I ordered.
Any thoughts on that other injector or the intermittent CEL light?
Thanks again for all of the assistance so far, I am really starting to dig this car, except for the cramped leg room, but I can deal with that for now.
Trent
