Mixing tires
A forum for the Nissan Quest... minivan lovers unite!
Djm2008
Car: Nissan quest
2016 QUEST.
Tires are half worn out but slip on wet grass driveway. Can I put new all season on the front only. Size 225 65R16?
amc49
Car: '11 Nissan Versa
'17 Nissan Altima
Yes you can, and I for reasons of my own do it on a regular basis here in Texas. When you change all 4 at once on a FWD car you actually are likely throwing away some tire that can run longer. I have only bought pairs for 20 years now on 3 FWD cars and no regrets doing it. The new go on the front and the old front go to the back. The backs are the ones that get junked. Of course, if you have all 4 new at same time then you do not have two that are ready to junk. That has to be worked out, but say a flat ruining one and makes it easier. Rear tires almost always flat more than the fronts.
Do that and averaged out you find yourself buying about 20-25% less tire overall. So almost one free every time you cycle 4.
The only thing I can think of to get in the way of it would be if you are in a northern clime where you positively need a lot of tread on the rear to help keep from skating around as much on ice.
amc49
'17 Nissan Altima
Thinking it out further, I would not be changing the tire size if that is what you are asking. CAN work but may complicate things.
far raf
Car: 2005 Nissan Quest SE (standard? simple? edition - i.e. nothing special)
ABS may get confused if different size tires are on.
amc49
'17 Nissan Altima
That is true and you are absolutely right. I was getting tired and looking for something else there and did not get that far. ABS pretty much wants the tire ODs to be close to the same to meter correctly.
^ Ditto all AMC said.
Return to “Quest Forum”
