DUH! I guess we should say "Fuel" from now on instead of "Gas" since we are burning a liquid. Or maybe we are watching "monitor" instead of "TV" since most people nowadays use a cable box and not the tuner in their set turning it into a monitor. Or that I need to specifically say I'm drinking a "Dr. Pepper" right now and not a "Coke" as that is the term in the south for all soda beverages.greggie195 wrote:Just to clear things up you are not using O2, you are using air. 78% N2/ 21%O2/ 1% "other"
I agree with this, you are drinking a Dr. Pepper, or soda, not a Coke as the Southerners say.Knightro2 wrote: "Or that I need to specifically say I'm drinking a "Dr. Pepper" right now and not a "Coke" as that is the term in the south for all soda beverages."
Ahh, the Grammar Police strike again!greggie195 wrote:Just to clear things up you are not using O2, you are using air. 78% N2/ 21%O2/ 1% "other"
Replace watching status bars..... with wait for PCR to finish and I agree 100%!Knightro2 wrote:Well, in that case I could call "Air" N2, O2, or Other if we are into shortening it like Gas.And yes, I'm going to keep arguing (light heartedly I might add so no one get flustered and mad) because I'm bored at work watching status bars of programs installing today.
This is true, BUT and this is a huge BUT..... Putting Nitrogen in tires is only effective if it is 95% nitrogen or higher!!! Less than that is useless!!! The Nitrogen molecules are larger than o2 molecules so it wont leak out over time like 02 does, also (like above) Nitrogen doesn't expand and contract like o2 does so you maintain your tire pressure better which leads to better gas mileage!! So you SHOULDN'T have to TOP off your tires and if you do, then there is a leak somewhere!! if there IS a leak somewhere then you can fill the tire with o2 just to get your tire fixed and refilled to 95% or better. This link is one company that sells a refilling station, but read the FAQ's:http://www.nitrofill.com/nitro....aspxSo, good luck and just read up on nitrogen, and you will be fine!!-JamieKnightro2 wrote:Nitrogen doesn't expand and contract as much as O2...excuse me...AIR does. So your tire pressure doesn't go up as your tires heat up on the road. Now, for most people this doesn't matter because tires don't heat up as much as airplanes or a NASCAR on the back stretch of Talledega that use Nitrogen as well. The main thing is as the seasons change, the pressure won't change.
Also, Nitrogen doesn't have moisture in it and isn't as corrosive as AIR so it doesn't degrade your tires as fast. But really this is not a benefit as for most people the tread will wear out far in advance of any degradation from corrosion.
The aviation industry and race teams have used nitrogen for decades...it's not a new thing. Just a new thing in the private sector to try and suck you out of money.
