zer0c123 »
https://forums.nicoclub.com/zer0c123-u10125.html
Fri Mar 04, 2011 11:53 pm
The tps sensor has three wires. The colors are solid black, light green with red stripe, and solid white (this one is thicker than the other two and is wrapped with an additional braided wire). You should be able to find those wires by peeling back the shrink wrap on the harness that sits on the fuel rail next to the injectors. If you need the connector, then you need to go to junk yard and snip one off. If you want a new replacement, then check out casper's electronics (google for the site). Their products aren't OEM, but it gets the job done.
