- Sometimes the dome light doesn't come on when I open the door. I usually does, but when it doesn't, there's no rhyme or reason. It's not after a prolonged period of time, it's not turned off, etc. It'll usually pop on after a few seconds, so maybe it's a sticky door switch? It feels fine to the touch.
Sometimes the camera stays on for a few seconds after it's in drive and moving forwards. It switches to the front camera. Not common, but it happens.
Another sometimes with no apparent reason - on a cold start and put in reverse, it won't creep backwards like is usually does. I have to give it a little bit of throttle to get it moving. This is on flat ground, and only on cold starts if the car has been sitting a day or so. Torque converter? Low ATF?
Possibly related to the above, the transmission has a whine in 1st gear. The dealer said it was normal, but I haven't heard other 7AT cars do this. It shifts mostly fine (see below), but I suppose it could be low on ATF. I'm tempted to get a flush, just to see, but it only has 34k miles, and don't feel like dumping $300 into something that's not needed.
The transmission has two personalities, again, no rhyme or reason... same throttle input, same roads, same engine temp. Sometimes it'll shift a bit lazily at 3k and generally be reluctant to shift quickly, and sometimes it'll shift quickly at around 2k and stay at very low revs (surprisingly low, like around 1k in a higher gear up a hill), with the torque converter locked up. It's say it's 50/50. Is this normal? Have there been TSBs or reflashes available for this transmission (RWD)?
Thanks.
