According to the diagram, and from memory on mine.....the side port goes to the actuator, and the bottom port goes to the compressor housing.sjbsuperman1425 wrote:so to hook it up, i would just put the bottom end of the MBC say towards the actuator, and then the side end of the MBC towards the compressor housing? Im a little confused.
ummm stupid question...RS12Turbo wrote:According to the diagram, and from memory on mine.....the side port goes to the actuator, and the bottom port goes to the compressor housing.
Did you drill a tiny hole in the side port? Suppose to prevent boost creep or something.
