maxima 99 a32 brake mastar cylinder
nice_man_36
Car: maxima 2001 GV full automatic
hello evry one im just need ur help and ur opinion also in this case i have Nissan Maxima 99 a32 and this car brake not strong front tire good but back side not good and i change every thing only 2 things not change booster and brake master cylinder this one with out abs
but when i chk master cylinder oil pressure to front tire its strong more then back side tire so is this problem of master cylinder or this normal
and this one need to change or i can repair
in this photo there is 4 pipe 2 for front side and other for back side
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Have you tried bleeding your brakes, that sounds more like what you're dealing with. The front pressure should be higher than the rears.
nice_man_36
thx elwesso for reply me ur correct front should be more then back side but car brake not strong from back side i don't know why i must push to last level to be strong brake and i also chk if there is air with oil in pipe but no air
elwesso
2007 BMW M Coupe
Typically the master cylinders are OK unless they leak, I'm not sure I've ever head of one being messed up causing inadequate braking to one axle? When you were bleeding the brakes did you ever let the fluid ever get to the point where it sucked in air? If you get air in the system there, it's really tough to get it out.
nice_man_36
100 % there is no air with oil inside pipe but also one more thing when u push brake its not soft its like hard i know i can feel booster its ok but also brake not good only back side u have to push strongly
