Max stock tire size on stock rims?
RedSubdivisions
Car: 1989 BMW 325i, 2002 BMW 330i
So...with the rebate check I'll be receiving with a few short days, I was wondering what's the biggest sizes (Front and Rear) I can put on the stock 7 spoke rims? If anything, I'll go 205/60/15 as normal, but any unique ideas? Anyone?
S13xCrazy
Car: 1993 240sx Vert, 1993 BMW 325i, 1993 Honda CBR F2, 1998 Infiniti Q45,
the fronts you cannot go any bigger with stock suspension.
The rears you can fit 65s on. Thats what i run.
RedSubdivisions
S13xCrazy wrote:the fronts you cannot go any bigger with stock suspension.
So basically 205/60/15 in the front and 205/65/15 in the back?
S13xCrazy
Yup, you might be able to go a little wider but I probably wouldn't.
vancouverbc
Car: 1991 240sx
I thought you want the sidewall to be smaller ie less than 60?
xckid
Car: 2004 Chevy Blazer ZR2
holy large sidewall batman thats a big one..
why would you run 65series...?? elaborate plz
....205 is what i run up front ..and 215 50 15 is what i run in the rear...
RedSubdivisions
xckid wrote:holy large sidewall batman thats a big one..
You run this on stock rims? The reason why I'm asking is because I plan to have the tires a little bit bigger in the back whenever I decide to dorifto. (which comes every once in a while; not a daily habit.) I just wanna get some ideas before I get new tires.
NismoDriver240
Car: 2005 STi
215/70r15 rear195/65r15 front
yes, there IS an engine under that hood
xckid
you confuse me your going with a bigger sidewall in the back to drift??? why...your going to have alot of sidewall flex unless your pumping up those babies with mad psi lol ...........
NismoDriver240 wrote:215/70r15 rear195/65r15 front
what to go mudding i know a few places
NismoDriver240
Car: 2005 STi
xckid wrote: what to go mudding i know a few places
i'm all set lol. they got rid of my fender gap and the car still appears to be the same height. im just gunna blow these tires since im getting new wheels and tires soon, but they fit on with no rub or anything!
sr20deTsomeday118
Car: 1991 240sx/se coupe
pics or ban
nissanman04
Car: '90 240SX, '95 Subaru Legacy
Why do you want a taller tire?
RedSubdivisions
lol I don't necessarily want a taller tire. I'm just looking for something that's better than the 195/60/15s I have now.
Dazzla
Not to bring up the thread... but I wanna throw on wider rubber on my rear 7 spokes. Will 215's fit?
I think I'm on 195/60/15 right now, but dont quote me on that lol
nifares240
Car: 1993 240sx Black-Project Car, 1993 240sx Red-SOLD, 1994 Sentra, 2004 Nissan Sentra SE-R SPEC V-Daily, 1999 Toyota Camry
I'm running on 225/50/15 on stock SE weels. you get a wider patch. there's no suspension rubbing issue as well. they look good too with it.
s13gebala
Car: 99 Nissan Maxima
91 Nissan SR hatch
225? wow.
mine are 205's and they seep out beyong the rim lip
SR20S13
Car: 1993 Nissan 240sx - SR20 INSIDE....
must have pics of both 225 and 215's asap please! thanks!
[email protected]
nifares240
i have 225 not 215
SR20S13
pics please???
240Chris
Car: '93 240sx
I've got 195/60/15 up front and 215/50/15 in the rear... I'll be getting new tires all around very soon but since i just dropped my car on coils, I'm not sure what would fit well and look good with my ride height set at what it is....btw i want to run either 205/60 all around or 195/60 fronts and 225/50 rears.. I'll post some current pics soon
Gabes13
Car: rb20det s13
Rule of thumb is that you can mount a tire thats ~2" wider than the rim. Anything wider probably rides like poo
SR20S13
well i got megan springs on my car and i was gonna put 215/60/15's in the back and 205/60/15's in the front....
240Chris
Car: '93 240sx
Now there are some positives and negatives to having 215 or 225/50 in the rear from my experience
Positives:wider contact patch - therefore -better rear end tractionlooks better if u like a wider than stock tirealso looks good from certain anglesshorter sidewall, but more sidewall flex could be a possibility(although i get less flex on my 215's than my tall azz 195 60's)- it depends on sidewall of specific tire
Negatives:speedometer shows a little fasterlooks ugly to me from side view b/c doesnt fill up fender gap ontop and on sides...(see first pic)- and they balloonless sidewall cushion (not a big deal)may get some understeer
here are my pics
Modified by 240Chris at 9:16 PM 1/12/2009
Modified by 240Chris at 3:41 PM 9/15/2009
MeanGreenS13
Car: 2011 Chevrolet Silverado 2500HD
i had 275/50/15 drag radials on my stock steelies for the track, a bit of a stretch but fit on there and had no issues.
Eddie
Car: 1995 240sx se
Quote:A Yokohama quick tip—use a rim width which is 90% as wide as the tread width of a performance tire for street driving. This will provide a good balance between performance and ride quality.http://www.yokohamatire.com/cu....aspx
For example: a 195/60/15 ES100 has a tread width of 6.8" and a measuring rim width of 6" which is 88% of 6.8".
Nissan new what they were doing when they equiped the OEM wheels with that tire size. Just put some sticky rubber on there and you'll be golden.
