amc49 »
https://forums.nicoclub.com/amc49-u275146.html
Tue Jun 11, 2019 8:04 pm
Pester them until they tell you. Often the intake air temp sensor is incorporated into the same mass air sensor (MAF) part as they are easily combined, they may have misconstrued the name on purpose to make you think they are changing two parts when they are only changing one and it sounds better to justify the too high price.
Ask them where the two are located, ask them what they do, don't just let it slide by, they are using tech terms and wrongly to baffle you more to cave in on 'more work' not done. It looks like the MAF can be changed in 10 minutes there and easy as spit. Of course you may well need a computer update of some type and don't be surprised at that. They could be talking about the primary O2 sensors there, they called that 'air fuel ratio sensor 1' back then and harder to get to to change.
FYI Rock Auto MAF price from $80-125 depending in if you want it with or without the round cylindrical housing, yours likely still useable. I looked at service manual and the only other part besides fuel regulator in fuel tank was a fuel damper in fuel line to damp out pump pulsations. Those rarely go bad.
Dealers often pull non-valid parts out of their -ss now to fuddle peoples' minds and get them to be quiet when stacking charges, they know a lot of people get confused by long wordy terms that may well be bogus and then the customer just lies back and takes it.
If you are not getting primary O2s changed there you are paying WAAAAAYYY too much.
