Wpgman »
https://forums.nicoclub.com/wpgman-u66701.html
Tue May 29, 2007 9:06 am
I am in need of changing one of the little maker lights located inside the headlamp.
I have tried to loosen the light by removing the bolt at the top of the headlight thinking it should slide or pop out. It seems to be movable but doesn't come out. I'm a bit hesitant to pull on it as I'm not sure if it's bolted in place at the base of the light or is held in place with a grommet and pin.
Can anyone help?
Modified by Wpgman at 1:18 PM 5/29/2007
