carmo »
https://forums.nicoclub.com/carmo-u91933.html
Sat Sep 06, 2008 9:50 am
The exhaust leak could be the reason for many of the problems. If your leaking exhaust before the 02 sensor, that will surely cause a problem. Turbo lag because all the exhaust isn't being used to spool up the turbo. Running rich because the 02 sensor is showing lean due to the leak. So, I would fix the exhaust leak before moving on. Maybe the severe rich issue is causing the idle problem too. I have a feeling that many of your problems are related to each other. You may fix four problems just by addressing one issue. Goodluck and keep us posted.
