making paper gasket
jt15833
Car: 95' 240SX
i'd like to put my oil pump on tomorrow but nissan says there is no gasket, just silicone, but when i took my current one off there is paper. I have some nice gasket paper that i cut out a pretty good gasket to fit the pump, you guys think this is a good idea? also, you think its better for the gasket to stick out a little or to be in a little where i can see the metal of edge when i put the gasket on? there is a tiny place where i cut to thin and i can see about 1mm of the edge of the pump where the gasket should be, im pondering making a new one, so is there anything bad about sticking out a little past where the two flat surfaces meet?
float_6969
I would try contacting one of our Nissan/Infinity sponsors instead of your local dealership. Maybe they can get you the part number or the gasket. If nothing else, print of the page in the FMS (Page EM-33) That shows that it's supposed to have a gasket.
Using home-made paper ones are OK, But I don't like using them on anything that's hard to get to, and the oil pump DEFINATLY qualifies.
originalsin
yea id have to say no to using paper gasket there too
jt15833
Car: 95' 240SX
there IS a paper gasket, nissan makes one i need to grab it, maybe you meant no to homeade but there is definetly a gasket
float_6969
There IS a paper gasket that is supposed to go in there.
biosehnsucht
SHOULD be part# 15066-16A00, alt part# (what you're likely to get) 15066-D5700; and thats in the US parts database - same as KN13 Pulsar w/ CA16DE or CA18DE.
just added it to my PartsDB, since I've already looked it up, I need to get around to actually finishing it up..
