BruceJ30 »
https://forums.nicoclub.com/brucej30-u79724.html
Sat Dec 20, 2008 7:22 pm
Alright, imagine that. Problem after problem...
Well, i was pulling up to a stop light. So i was braking, going about 15 MPH, and then it went green so i stepped on the gas to accelerate. I DID NOT floor it or even put the pedal down halfway, i just barely put in gas. Just enough to start accelerating again. And then right after i stepped on the gas, i heard a noise and then the car jerked a little. It's hard to describe on here, but it was as if the car was in neutral. So i went down through all the gears (D,3,2, and 1) And still had nothing. No power and the car just revved. So i had to get out in the road in the middle of the night and push it to the nearest parking lot.
What do you guys think the problem is? I don't think the transmission blew because i had no problems with it before this happened. So I'm guessing the torgue converter?
I checked my transmission fluid, and it was at the appropriate level.Also, i changed the transmission fluid, and filter about 9-10,000 miles ago.
