M56 BCM swap
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
splitnails wrote:
Mon Mar 14, 2022 6:21 am
What would y’all do? :(
Use your nose and track down the burn. It could be a melted wire or connector, not just the BCM itself. If it is the BCM, I'd split the housing (easy to do, just plastic pawls) and see if there's a burnt trace on the PCB. Those can usually be fixed by soldering a wire across the injury. Post pics either way, melted wiring or connectors may get complicated but can usually be circumvented if not repaired. Once you locate the burned circuit, we'll make suggestions.
Pakitullanc
Car: 2012 Infiniti M56 S
You have to get a VIN match BCM (dealer parts dept can help) I bought mine from ebay for $50. Then you need this harness.
