ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Sat Feb 12, 2011 3:44 pm
If there is a grease fitting, usually near the knuckles of the u joint fitting, grease it and watch the end of the shaft, feel as you grease, you want no increase in effort to squeeze the grease in but the grease has to go to, through the fitting and push out the old grease. Look around on and at the body work, there will be a sign of grease flinging out at the exit point and line that grease mark up with the rotating shaft and you should find the exit site. Keep the input and output points clean. The removing grease will stop rusting where it lands on the underneath body parts.
