LS1 and LS2 Coil Pack harnesses - Only $99 - http://www.wiringspecialties.com/ls1cohaprose.html
The Wiring Specialties PRO SERIES LS1 & LS2 Coil Pack Harness is designed for a direct drop-in installation into any chassis utilizing the LS1 or LS2 engine.
PRO-SERIES HARNESS INCLUDES
• Brand NEW Construction
• High Temp Nylon looming with adhesive shrink tubing
• High Temp wire (280 degrees)
• OEM connector specs (no cheap aftermarket connectors that fall apart)
• Designed for a factory-like installation
• OEM wiring connections and 'T' junctions. No soldered
• Fully tested after production for an easy plug-and-play replacement
• Turn Key ENGINE START Guarantee
• Tech support for our customers 7 days a week.
