Lowering question/New here/toe rods???
z32slidewayz
Car: 94 300zx na
I have an NA 94 300zx. Already bought front and rear adjustable control arms and megan springs (i wanted the drop) my question is, when we lower the z32 suspensions, does that effect the rear toe at all? Do i need to buy a rear adjustable toe arm? Any help is greatly appreciated. Its a 2"f and 1.75"rear drop. :confused:
javadave
Car: 1990 300ZX 2+2 NA 5-Speed
The rear toe is adjustable already, so no, toe rods are not needed. It is highly recommended to install solid adjustable tension rods in the front. Use without solid spherical ball joint tension rods can prematurely wear the bearings in the front cambers arms due to variance in castor allowed by not using the proper tension rods.
z32slidewayz
Car: 94 300zx na
Thanks for the reply. I was wondering what all else i would need. Much appreciated javadave!!!!
