Jordan
Thats what I thought. Now, when that baby does decide to break free make sure you ain`t under it lol.Reverend D21 wrote:Sounds like the centering bolt is stuck inside the axle perch and needs some persuasion to come out. That or you are trying to lower a 4wd which won't work. Try spraying the perch down with some PB blaster then use a mallet to loosen things up. With your truck being an 84 there has been plenty of time for the center bolt and the axle to become friends. There is no reason to loosen the centering bolt, it only sits inside a hole on the bottom of the spring perch.
Thats what I`m screaming about. Reminds me of when I dropped my `84, the one in my avatar. I truly miss that little truck.Bubbas Garage wrote:http://www.cardomain.com/ride/3921266/1 ... 720/page-1
Click on the pics to make them bigger!
