Sentientbydesign »
https://forums.nicoclub.com/sentientbydesign-u25395.html
Sun Nov 12, 2006 6:56 pm
Timing IS everything. I just went over to my dads and he and his mechanic helped me install the new bushings.
First of all, I wouldn't pay a mechanic to do this job with one exception. You need the right tools. We used SAE and metric bits. Some as large as 24mm. And high torque socket wrenches. I didn't personally have all of the tools but my dad did.
You don't actually need a machine shop. The old bushings can be torched and sawed off with a reciprocating saw. I'm not going to say that it was all easy work, but taking them off and putting them on wasn't bad, just getting the old bushings out that was a pain.
Torch the transverse link bushings. They will be a pain to get off but once they start burning, you can get a flathead screw driver and pry them off. Then you'll need the reciprocating saw to cut the thin metal shell inside the control arm. BE CAREFUL NOT TO CUT THE ARM ITSELF, just the small pipe that held the original bushing.
What you will need the machine shop for is the ball joints. They have to be pressed in and out. You should check to see if yours are warn and how well them move once you get them out.
There is a tunning fork like tool used to push the ball joint nut out of the hole it's in. It was very helpful. You don't pop the ball joint itself, just the screw portion away from the wheel assembly.
Take apart and put together took about 30-45 mins. Getting the old bushings off and figuring out that we needed to cut them was the long part.
My ride isn't very soft as I have eibach springs and tokico illuminas set to 4, however I noticed no degradation from installing the new bushings. There was NO press work needed. Just cut the piping in the transverse link and pop the new bushing in. A large C clamp helps to get the bushing in there nicely though.
